XJS Brake probem
Guest
Posts: n/a
XJS Brake probem
Hello all.
I'm hoping one of the Jag experts here can help me. We recently replaced the rear brake calipers and rotors on a 92 XJS V12. Awesome brake pedal, excellent stopping. The problem is on quick brake pedal application the brake and abs lights come on simultaneously and go off 1/2 second later. Upon normal brake application the lights do not come on.
Anybody had this problem?
Couln't be easier
First, you'll need a hex bit for you ratchet - I forget what the size is. You may want to evacuate the back pressure by hitting your brake pedal 20-30x without engine on. Get a good grip on the motor because it may take some pressure and you don't want to break the mounts. Unscrew it and pop on the new one - and Bob's your uncle !!
Probably common knoweldge, but I'll say it anyways -- these things only last 10 years and the nitrogen leaks out. Be careful of cheap accumulators - the usually windup being NOS - ie, 1993 - 17 years old and probably on death's door from the second you mount it. Be sure to buy a NEW one from a reputable seller. I use Rock Auto. $165 +/-
ACDELCO P/N 25528382 (GM used the same teves system in the late 80's / early 90's)
