XJS-C
Old 06-28-2016, 09:53 PM
Michael Haughey's Avatar
Default XJS-C
Hi.. I live in NZ and am having trouble working out the year of manufacture of a Jaguar XJS-C that I am selling for a friend.. It is listed as a 1980 on nz records but has been deregistered at some time so this may be incorrect.. It is a V12 targa top with a rear seat.. Did they even have this configuration in 1980 .. It has BL on the manufacturers plate but I think the vin is a New Zealand issued one as it doesn't seem to line up with Jag Vin numbers.. Vin number on Nz records is 7A899010796103232.. It also has a chassis number of JNAEW3AC103232 and engine number 15416.. Any information you could provide on this vehicle would be hugely appreciated.. Nobody over here can tell me anything about it but some people have said it is later than a 1980 model.. Many thanks..Mike..
Old 06-29-2016, 02:21 AM
GGG is offline
Received 16,851 Likes on 12,186 Posts
Welcome to the forum Mike,
I've moved your question from General Tech Help to XJS forum. This is the place to post questions about your model.
I think your chassis number decodes as follows:
J = Manufacturer: Jaguar
N = Model Range: XJS
A = Class: Base Spec
E = Body Variant: Coupe
W = Engine Variant: 5.3 litre
3 = Transmission & Steering: Auto/RHD
A = Model Year: 1980
C = Emission Control System: Middl East - Emissions D
103232 = Production Serial Number
The VIN number you quote from NZ records does not follow the international standard but the US used to allocate second VIN's on import and NZ may have done the same.
Old 06-29-2016, 04:40 AM
ptjs1's Avatar
Received 3,033 Likes on 2,015 Posts
Mike,
VIN 103232 was a vehicle made in late 1979. So it's either a 1979 car that's been converted into a Cabriolet or it's an original Jaguar Cabriolet that has been "given" the VIN plate of an early car. However, that engine number is also a "pre-HE" number, so that would tend to indicate that it is an early car that has had an after-market conversion to a Cabriolet.
If you could post some pics of the car, we could probably help you identify if it's a converted car or not.
Hope that helps
Paul
NCJagman
04-15-2016 12:40 AM
klfong
04-07-2016 05:51 PM
Noel619
04-04-2016 08:18 AM
byjosh
04-01-2016 02:11 PM
axel1961
03-31-2016 08:34 PM
Quick Reply: XJS-C
