XJS Chrome
Hi
Can anyone tell me when the front bumpers changed?
My XJS 4.0 1992 need new bumpers but I am not sure which model years
will fit. I am looking to find second hand as re chroming quotes seem high
to me. My car has headlamp washers but not too bothered if the new bumper
does not have these fitted.
Any advice welcome
Any advice welcome
from what I can tell you should be okay with any facelifted XJS. I think the front bumper gets changed to a painted plastic, but the chrome is retained.
I think the chrome from a pre-facelift will work, but if you look pretty much all facelift cars use the washer to join the pieces of the chrome together, where the older cars have a rubber seal. The shape looks the same to me, but you may as well go for the facelift car and retain the same look.
Hopefully someone can confirm
XjsJack (10-20-2014)
XJSJack,
In theory, the chromes from introduction of facelift in 1991 (VIN 179737) up to introduction of Big Bumpers in 1993 (VIN 188105) will fit your car. However, although some of the chromes will fit different years, we have seen slight differences in the profiles which can give problems if trying to fit parts together of different years.
If you want to be precise, go by VIN number as per Jaguar's website here:
Bumper With Absorbers-Front - Parts For XJS from (V)179737 to (V)226645 | Jaguar Heritage Parts UK
Good luck
Paul
Good luck
Paul
XJSJack,
Sorry, just to add, the bumpers, bumper beams, mounts, trims, vents and even wings are different from VIN 188105.
So you need bumpers and chromes from 179737 to 188105, although there are changes to the part numbers for the chromes even within that range. However, if you are changing all 3 chrome parts separately, you should be OK. Be aware that when you take off the bumper, there is every likelihood that the beam will be rusted underneath.
Paul
Paul
XjsJack (10-21-2014)
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
1964Daimler
09-09-2015 11:28 AM
