XJS convertible Quatre window not lifting
You can start by getting a looooong screwdriver or something and tapping the window motor. That should get it to work, at least for a little while.
You should remove the plastic clip that faces the window (when it's up) so that you can get to it if it gets stuck in the up position.
After that, you should search the forums for solutions to this common problem. (I have a post with pics somewhere)
It's undoubtedly in a slow death spiral. Tapping it back to life might get a few months before it happens again, but then the frequency keeps getting tighter and tighter, so I recommend you figure on a plan now.
Replacement is not a cheap option, and not entirely recommended since the new motors are not available, so you'll just be gambling with someone else's ticking timebomb.
I do wish someone would come across a motor that can be purchased new which could be easily transplanted.
When I first got my car I had this problem on the passenger side. I actually found a fix that worked ever since about 3 years now and that is to insert a piece of hose in the bottom of the slot in the frame. I used a silicon hose. I think the hose acts as a spring because it’s compressed by the window and it helps get the window moving. You can access the frame through the vent in the door frame. I will see if I can get some pictures.
Rob.
Rob.
The following 2 users liked this post by Robbo D:
arcticsilvere39 (05-15-2023),
ptjs1 (05-10-2023)
Greg in France (05-11-2023)
Usually when the windows fail to move it's the relays. The way they are wired is there is the power to go up is through one relay and the ground is through another relay. This reverses to go the opposite direction. The relays are typically rated lower on the opposite contact, so it's usually 30A on the normally open contact and 20A on the normally closed. They burn contacts on the lower rated direction, so it's important to check that the relay can carry current on both contacts.
If they are original, I would replace them all with new, 40A relays. That cured the problems on my car anyway.
I swooped the window relays over , which are located next to the roof pump, to opposite windows. That didnt cure it. Could it still be the relays?
Zarathustra,
If you look at the wiring diagram, you'll see that it doesn't have fuses on the rear windows. It has individual L & R thermal breakers providing a feed signal to the Up & Down relays.
It's time to get the multimeter out.
Maybe start by checking for voltage output to the motor circuit from the Up relay on the non-operative window when the hood switch is pressed. Remember that you have to wait 8 seconds before the window is signalled to rise. If that is ok, then check at the motor connection itself. If that is ok, then it's a motor problem.
Good luck
Paul
Good luck
Paul
Originally Posted by Zarathushtra;[url=tel:2640884
2640884[/url]]Hi,
I have a 1992 4.0 xjs convertible. I put the hood down yesterday and on putting it up the passenger side rear quatre window did not lift. Is there any advise/help please from anyone?
Thanks.
Thanks.
So I was actually just able to fix mine. It wasn’t a motor issue after all. Last night I removed (it had actually already fallen off) the cover plate that protects the interior unit that the motor drives. I cleaned and greased it and still didn’t have luck. However today, I noticed it was extremely dirty and gritty on the window side of that unit where the main gear meshes with window regulator. I used electrical spray to clean it, some dry lubricant and just a little WD-40 (cause I ran out of the dry spray). And bingo, when I hooked my 12v source up to it it raised perfectly. I’m pretty confident there was a small rock or piece of debris lodges between the two gears. Maybe give that shot.
Greg in France (05-14-2023)
Thabk you everyome for your help. I found the fault on mine to be a loose connection to the motor feed.
Greg in France (05-21-2023)
