XJS cross member feeding the roses
So, hi all
Yesterday was a great day, but for the fact that I drove my beloved XJS onto the curb at just the right speed to result in a bent crossmember, front axle, subframe - call it what you may. Nothing else has much been compromised, but the subframe is a goner.
No idea what one does in these cases: get a refurb one, go to the junkyard, try to fix/straighten the damaged one, forget it altogether?
If there's any ideas or suggestions out there in the infobahn, or if someone has a spare subframe, because some people do stock up on subframes, let me know.
Any help at this point would be greatly appreciated.
So, hi all
If you hit the curb in a manner to damage all those things be sure and check your wheel its probably bent also
nonfinito (01-13-2015)
The following 2 users liked this post by Greg in France:
nonfinito (01-13-2015),
orangeblossom (01-09-2015)
nonfinito,
Sorry to hear about the problem. That's not one I've heard before. Rusted sub-frame, that's common. But a bent sub-frame is very unusual. I tend to agree with Greg that the only way that might happen would be if the sub-frame was significantly compromised by corrosion. Either that or you must have hit something with a hell of a thump. Therefore I would also check the sub-frame mounts haven't tried to rip out of the body.
If you buy a sub-frame, buy it bare and thoroughly check it over for corrosion in the usual places, especially those hidden lower spring pan seats. You can then ensure its integrity and rebuild all the front susoension, bearings and brakes as part of the refit.
Good luck
Paul
Good luck
Paul
Jaguar Forums Editor
Jaguar Press release
09-05-2015 10:08 AM
09-04-2015 09:18 AM
09-03-2015 09:38 AM
