XJS Cup Holder
Received 10,916 Likes
Heh heh. The XJS is perhaps best described as "Ye Olde Worlde Class" ? :-)
I will use the money I save on the ski slope to buy the Japanese, German and American parts needed to address the problems and improvements outlined in Kirby Palm's 700+ pages of XJS issues. Once things are updated hopefully I will develop a love/like relationship with this car, which you apparently have with yours, instead of the like/hate relationship I have with it now.
Hang in there.
When I bought my XJS (this was years ago) it took me six months to sort out the bugs, catch up on neglected servicing, and make all the repairs the previous owner never bothered to do. In the end I was rewarded with an XJS that I could jump into and drive anywhere with confidence. Fabulous car...someday I'd like to have another.
While I was doing that I experimented with some 2 1/2" and 3" PVC male adapters. These would work great as cupholders (suitably covered in matching leather of course) but are too large a diameter to fit within the ski slope. But, if you shift the shifter (pun intended) over about an inch you have plenty of room. The PVC male adapter works great because you have a threaded end, and you can go and get a lockring from a 2 1/2" or 3" EMT metal conduit adapter and basically screw it right to the ski slope after cutting the hole out with a hole saw.
Plan is to make a replacement ski slope out of plywood (making my own plies from 1/8" to get the curve) with the shifter shifted and the leather-trimmed PVC cupholder. It'll be a while before I get around to this, though. If anyone wants to beat me to it, feel free.
D
D
Cup Holder for Poker Tables, Drop In Drink Holders for Poker Tables
Hang in there.
Hang in there.
ive had mine for a month and 8 days, and ive only just scratched the surface. (total engine harness rebuild, cam cover gaskets, water rail gaskets, all new hoses, radiator hoses, crossover hoses, vac hoses, new TPS, New ECU, couple new injectors, etc. etc.)
NO! Don't use PVC! Use poker chip cup inserts for poker tables. Check these out.
I've not bought a ski slope from British Autowood, but I did buy a shift knob. It's the one with the old "Coventry" Growler, and the mother of pearl inlay. It's quite nice, and feels much better in the hand than the original.
Seems a bit extravagant but the price had been reduced and I couldn't resist.
It doesn't look as out of place as you might think. It really looks nice in there.
I want a ski slope, but I want a bit more than that. I'm fed up with the stupid junk lighter socket in mine falling apart, and that broken million-dollar junk plastic bezel.
I want a ski slope with a hole drilled in it so I can fit an outlet similar to this, and trim it with a nice polished aluminum ring:
http://farm5.staticflickr.com/4125/5...e2fdfcae_z.jpg
Of course, if I'm doing that, I should probably axe the proprietary speed control bezel as well. It's only going to break some point in the future when they can't be found readily. It's easy enough to find a nice replacement switch from the NKK catalog and make a better bezel out of aluminum.
That means I'm going from scratch on the slope itself, but that isn't difficult. It's just some bent metal, and I'll have a chance to insulate it properly. That's only twenty or thirty bucks at a water-jet.
There was a guy a while back who was making them out of carbon fiber in effort to keep the heat at bay, but I don't know what happened to him, or even if it turned out to be a good idea.
I want the cup holders as well. The ash trays are a bit garish and outdated, even in such a classically styled interior. They remind me of an armrest ash tray in an '80s American sedan. They are also incredibly annoying to reinstall after removal.
Either way, I hope British Autowood will laminate the result.
Currently, I've found it very effective to simply drink bottled beverages and place them between the seat-belt clasp and the center console by my hip. They aren't in any danger of falling about in that position.
It's not safe to keep a beverage between your legs, as it can become loose and interfere with the pedals.
#30
What u have with the XJS is a world class automobile. I highly suggest NOT cheapening it by using $10 cup holders. U R driving a Jaguar, not a Chevy. So if u must drink and drive, go ahead and get the ski slope veneer with built-in cup holders that replaces the ash trays. If you smoke and drink while driving, perhaps a pick-up truck would be better suited for the task than a $60 luxury car with beautiful leather and veneer? I believe any changes to the car should improve it, not cheapen it. I dont mean to sound trite. I drink coffee in mine too. I bought the ski slope. U will be glad u did too.
M90power (05-03-2012)
#31
I'll be the first to admit that "text language" irritates me when used outside of its intended purpose, which was a crude method of messaging on a cellular alpha-numeric keypad.
However I think it's important to remain respectful when we disagree with our fellow forum members and not try to neutralize their opinions by pointing out unrelated flaws in their posts.
I've met some absolutely brilliant people who could not construct a sentence if their life depended on it, and on the flip side I've met some grammatical whiz-bangs who couldn't cut their way out of a wet paper bag with a sharp knife and a GPS.
#32
The main problem I had with my ski-slope from British Autowood, was that the new ski slope was thicker so now the bezels don't snap in anymore. I would recommend making the holes for all of the accessory stuff slightly larger on the water jet so that the wood overlaps the metal holes by a bit. The bezels can't work through the thickness of both wood and metal.
...unless you're making custom bezels. If you are, I'm pretty sure you can make a decent amount of money selling them to others, including me.
#33
I'd consider it butchery on my own vehicle, and while I can't always easily afford expensive parts, I'm more than content to save money and deal with an issue or modification project when I can remedy it to my satisfaction.
Suggesting, however, that someone should buy a pickup truck (especially considering the implication that pickup trucks might be lower-class vehicles than those pertinent to this discussion), simply because they don't see the value in, or cannot justify an expensive modification is fairly grating.
With that as context, one would expect such pretensions of class to be accompanied by equally high-born language.
Not everyone cares to sit about and wait for expensive parts, and not everyone is concerned with the results of cheaper alternatives. They shouldn't be mockingly directed to a different car, simply because their tastes aren't in accordance with the original market price of an XJS.
Perhaps the greatest facet of a Jaguar vehicle is the fact that nearly anyone can enjoy one, in nearly any way they can imagine. You aren't buying your way into class, you are driving your way into pleasure.
I simply illustrated the contrast between claim and communication. That is all. I don't consider that a disrespectful observation of an opinion (again, an opinion with which I largely agree); I consider it a respectful defense of a different perspective by way of contextual dissection.
You'll never catch me berating someone for a procedure or modification of which I do not approve, unless I find it to be dangerous and deem it appropriate to communicate the risks, or the associated member asks for critical opinion.
#34
It was British Autowood. They stopped doing it a few years back, about 3 months after I placed my order. He had a good reason, but I forgot why. You can ask him.
I will indeed be making custom bezels, or at least designing and partially participating in their making. I've got friends with a machine shop, another with a water-jet facility, and immediate access to powder and ceramic coating services, so I'll generally make or have made parts to my taste, or those that I can't otherwise afford.
It's crazy, but the result will be cheaper than a new plastic bezel... Mr. Goorganpalang on Ebay seems to have the supply locked up.
Still, one's finances aren't always at the same level as his ambitions. I'm not going to be doing it tomorrow.
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
I'll try my hand at a factory replacement, though. They would be good to have on the market. I'm fairly good with parts design. I'd keep an eye on Paul's Jaguar, however. They've already developed and marketed an improved replacement window switch bezel (I've got one, and it's wonderful), and they sell them for peanuts. I'm sure a cigar lighter bezel is just around the corner.
Right now, I've got to get that climate control working properly. I replaced one blower with a rebuilt unit, and the other failed shortly after. Then, a vacuum actuator sprung a leak... Sometimes, you've just got to smile at the lunacy of it all.
#36
Yes I was doing them out of all-carbon at one point, but it just turned out to be more of a hassle than it was worth. I have recently switched to aluminium of the same thickness which is working out great.
Yes you've got to watch those plastic switch bezels, those small tabs like to become brittle and break off -- they don't always want to go back in and sit flush anymore. As mentioned, Paul has the replacements I think.
Cheers,
#37
I am liking my XJS and that motor, more all the time. I have addressed a couple of issues and I'm slowly pecking away at others. This doesn't mean I won't change the ski slope to a cuo holder type or maybe even add some some dingle *****, fuzzy dice and a hula girl for the dash. Those cosmetic upgrades will have to wait for a couple of other upgrades, you know the ones that aren't as much fun. I have decided to go ahead and replace the radiator with a Be Cool, install electric fans with thermostat and a/c control and while I'm at it replace all of the hoses t-stats and other marginal paraphernalia. I also plan on cold air as my next project.
My relationship with the car has gone from like/hate to like/tolerate and the more I drive it the more I like and tolerate it.
salP3082
09-25-2015 05:07 PM
280zx-turbo
09-10-2015 06:29 AM
