XJS hard to start
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hi, i have a 1989 XJS V12 that is difficult to start after being left for 4-5 days. To start i need to turn the ignition on 20-30 times without engaging starter to help get fuel to engine i suspect and then engage the starter 3-5 times before engine begins to fire but not start, after about 6-8 times it starts. Once started she runs great and starts nicely until left again. Needed to install powerpoint so i can run a trickle charger to charge my battery. It is very annoying!!. I have had fuel pressure tested by mechanic and was ok. recently replaced fuel pump and it seemed to improve the problem for about 2 weeks (not fixed) but it is now behaving the same as it did with the old pump. Any information/ideas on what i can do to determine what the problem is or to fix it would be greatly appreciated
Clearly the fuel pressure is bleeding off when the car sits. Does your car have dual fuel pressure regulators on the fuel rail? My 1992 V12 sedan did, but there are differences between the XJS and Series 3 cars. I'd start by replacing both (if applicable) of those and go from there.
The Series 3 had a check valve in the boot fuel plumbing, but I think that was because it was a dual tank car, the XJS has a different tank and plumbing arrangement. Does your car have an in-tank pump or external?
If you want, all the parts diagrams are here: http://www.jaguarclassicparts.com
mappelbee (02-02-2013)
Received 10,871 Likes
You should be able to hear the pump run from the driver's seat if you listen carefully. Do you? If not, post back
Or, have a helper turn the key on a few times while you listen for the pump to hum at the rear of the car. (The pump is locatd behind the spare tire)
Welcome to the Forum.
Please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'
I've moved this thread to the XJS section for better help.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
