XJS headlights
#41
Like I said... they come in different temperatures. I likes it cold, and pure white, on my white car. No mimicking. In your case, order a set of the temp you want and go driving. Simple.
#42
After much consideration, I ordered a set of LED headlights and reverse lights from Gil Keane at Better Car Lighting in the UK. All my questions were answered promptly and professionally, with a good dose of humor thrown in as well.
Currently running Sylvania 9004 SilverStar Ultra Halogens, as reviews indicated they were the best/brightest I could get in halogens (that were available locally). I've driven with these at night only a few times, and they are quite good. However, my local roads are almost uniformly well lit. Want the LEDs because I sometimes travel at night to somewhat more remote areas with little to no road lighting.
More as it happens.
More as it happens.
#43
I'm still learning about LEDs but that explains why they seem to be more prone to failure (at least seem to be more finicky). Or maybe I just get unlucky with a bad egg every once in a while. The thing is these bulbs are made all over (mostly China I bet) and quality control is questionable. I've tried all brands. I'm speaking of floodlights here (household) and ceiling can lights of which I have at least 50 inside and another 20 or more outside. As for automotive LED lights I do not have any experience with them - but perhaps my wife's 2015 ML350 has them? Haven't had it long enough to know yet.
#44
We were running some expensive Incandescent halogen headlight bulbs in my wife's '92 XJS coupe as well., but with the Euro Style headlights - not impressed (and the lenses are still clear). We finally spent the money for a set of the better rated (HR) LED headlight bulbs. A fairly simple install, and WOW - completely blew the Halogens away - not quite as good as the OEM LED headlights in my 650i GC, but in the ball park. We consider them worth the money and warranty included..
#45
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1370/jagsmall_6f55f862136aa9492c709dfd5bbc929c3545cf48.png)
Hmmm the '95 didn't have sealed beam quad headlight, it has the one piece Euro headlight. I believe some came with glass fronts and later ones with plastic fronts. Both kinds take H4 bulbs accessible from a removable panel in the wheel arch / fender .
The main problem with US sealed beams is that they not only don't dip to the side they also have a much lower wattage than H4 bulbs.
My '92 MY with wires, quad headlights and a small leaper, which uses the same holes as the growler so l can change out at will..:-)
