XJS help
My license plate lights and tail lights don't work and i cant seem to find the problem. Trying to save myself from a $200 citation at court on tuesday. I've checked the fuses and they are fine. All wiring seems to look in good condition. Also my dash lights don't work and again, fuses are good. Any help from anyone with some knowledge or the same problems?
Also tackling my spark plug, cap and rotor project tomorrow. How long will this REALLY take me? I have the kirby book and the "accessing the V" page. Sounds pretty straight forward with a few hassles
It would help if you added the model and details to your signature.
Is there voltage at the lights? pull the connector and measure for voltage and take note of the readings and post them back.
I assume it's a V12 I did mine by removing everything from the V makes it easier to re-install the plugs without fear of cross threading them, took me a couple of hours. You can do it without removing everything using a piece of hosepipe to re-install the plugs.
I also find it good practice to take pictures of everything as I dismantle - makes putting it back together easier especially where shims are involved.
Cheers,
- no dash lights could easily be that the bulbs are out.
- I am no mechanic at all: did my cap and rotor (not plugs & wires) the other day for the first time. Reckon I could do them in half an hour now. Some of the plugs look a little difficult to reach. I understand there is a specialized tool available.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
