XJS hood release
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
I have a 94 XJS ragtop and the right side hood release quit "releasing".
now what do I do?. Left side works fine, can't see squat under the hood (bonnet).
Any suggestions welcome, if I can't do it I'll have to two to shop (also
had a coolant leak, thats how i found the hood quit working)
Tried wiggling as suggest and keeping the release all the way pulled out inside the cockpit., no joy.
Has anyone ever removed the hood from the front with a latch that would not release?
Can the hood be removed by unbolting the hinges after removing the Grill and spoiler? Can it be accessed AFTER taking all that stuff apart?..
Sounds like the cable linking the driver's side latch/release to the passenger side latch/release is broken. This happened to me and I had to replace the cable. It happens.
I removed the front grill and then removed the (4) bolts attaching the hood to the body and was able to slide the hood forward enough to remove the hood.
WinterJag
16
10-09-2015 07:49 PM
Pluckie
10-03-2015 07:57 AM
Rochester
09-14-2015 07:58 PM
