If you are going to buy an XJS and are intending to work on her yourself, then rather than pay a Garage/Shop $100 per hour.
You need to consider at the least getting yourself a 3 Ton Jack and some Axle Stands, or else do what I did and get a Hydraulic Lift.
Which has given me very excellent Service up to now and made working on my Car a whole lot easier.
I bought it several years ago from a Lady who owned a Circus 'Like you do' and had a lot of fun getting it home but that is a very long Story.
The Problem now is that the Electric Motor started smoking and packed up, so now needs replacing.
So while I was at a 'Yard Sale' I found a battered old Saw Bench that was only £10 and while the Blade was all seized up, I was only interested in the Electric Motor and so for only a 'Tenner' I thought I'd take a punt.
And after I managed to get it home, I tore the thing apart where after a bit of TLC I got the Motor running like a 'Bird'
Just the thing for my Hydraulic Car Lift (or so I thought!) except there is a problem!
(I do hope Warrjon is reading this!)
The Original Electric Motor ran 'Anti Clockwise' but this Electric Motor runs 'Clockwise'
Which means it would Spin the 'Hydraulic Pump' the 'Wrong Way'
So my question is: could I just Swap the fittings over to the other side or make the motor run the other way?
The problem is that I cannot open the Motor, to change any wiring, even if I knew what to do which I don't, as the bolts and fastenings are to rusty to come apart.
Ideally I could run the Pump in a 'Clockwise' direction if that is possible and if that would work?
If I was able to do that, I could take the coupling off the Old Motor and drill it out for a 20mm Shaft and maybe chop a little bit off the end (its a bit too long)
Then drill and tap the Face Plate and bolt it altogether, then just plug it in and lift the Car but it probably won't be quite as easy as that.
The Motor and Pump would be used in the Horizontal Position, not vertical as in the Photo.
Ideas wanted please guys.
My Trusty Hydraulic Car Lifter, now sadly minus the Electric Motor.
Scrap Saw Bench, gotta be worth a 'Tenner' just for the Motor and I can use the Table for a Welding Bench
The Old Electric Motor which Spins Anti Clockwise.
The only good bit on it now is the Coupling
The Motor out of the Saw Bench, which runs Clockwise.
I was planning to Tap and Drill the Motor Head and then Bolt it together.
The Motor and Pump would be used in the Horizontal Position not up on end like this
This is the make and model of the Hydraulic Pump
Details of 'The Electric Motor' which means nothing to me!
But it runs a lot better than it looks
Except it Runs the Wrong Way for the Hydraulic Pump
The Hydraulic Pump runs 'Anti Clockwise' but the New Electric Motor runs 'Clockwise' Arrrgh!
My New Scrap Saw Bench Motor in all its glory!
If only it ran 'Anti Clockwise' all problems would be solved (ish!)
Your pump runs anti clockwise, motor runs clockwise. By that I would guess your lift lowers by bypassing the fluid, so changing the fittings or lines going to the ram would not work. Your motor looks to be AC and I cannot tell you much about those, but in thinking, is the pump running anti clockwise when looking at it from the bottom where it attaches to the motor? If so would not the motor with the shaft sticking up inside that area be turning the same direction? Hope that does not get to confusing.
Hi JL
The motor would be turning it in the opposite direction to the way it was running before, ie 'Clockwise' which with the benefit of hindsight, is why they use them on Saw Benches as otherwise the Blade locking nut might start to come undone. Ooops!
Still nothing lost for a 'Tenner' the Table Top is worth that to me to use as a Welding Bench.
So maybe it's back to the drawing board unless there is a Hydraulic Engineer in the House?
If reversing the motor is too difficult, could you mount the motor with a toothed wheel on the end which then engages with a toothed wheel on the pump coupling. You would thus have reversed the direction of travel from the motor to the pump.
Hope that makes sense!
Paul
PS Just noticed that I have a PM from you! Apols for not noticing earlier. Will respond later. Cheers.
Paul
Hi Paul
I get what you mean but 'fabbing' that up could be a bit complicated.
Hopefully Warrjon will be able to come up with a 'mirracle solution' what he doesn't know about Electronics, you don't need to know!
Your motor is a split phase motor P1 and P2. One of the windings will have a capacitor in series, you need to identify this winding and reverse its polarity.
With an AC motor the voltage has NO bearing on which direction the motor spins (unlike a DC motor) its the magnetic field generated by the direction of current flow. It's quite complicated as it actually need the current in each winding to be 90° apart.
OB can you take a pic of the inside of the box on top of the motor. Hopefully I can identify which wires to swap from the pic. If not you'll need to get your DMM out.
I got rid of the diagram as I thought it was confusing
The Box on Top of the Motor is a bit corroded, including the screws that hold it on, so I will probably have a bit of a problem trying to get the lid off and will have to give it a good spray with some penetrating Oil.
I managed to get the Cover off and was able to take a few Pics, so hope they help.
My knowledge of this kind of Stuff is Zero, so please keep it all as non technical as possible as I don't know what a Capacitor is or even what it does.
But I'm guessing its that 'Silver Thingy' on top of the Motor.
OB, if you swap the blue capacitor lead to the RED AC and Z2 to U1 the motor should reverse.
I am making an assumption that Z1 and Z2 are one winding and U1 and U2 are the second winding. You can confirm this by measuring each winding with an Ohm meter they should read around 1hom.
