XJS Map lights working opposite
Am hoping for some advice solving the following map light problem on my XJS. Light switch 1 ( on the left side of the 2 switches) turns on the light on the right side of the car. Light switch 2 ( on the right side of the 2 switches) does not turn on anything. Both switches light up when they are depressed.
Any help appreciated.
Thanks.
Thanks.
YycXJS (11-11-2013)
The centre roof light can be set by rolling it fore and aft, to be on all the time, off all the time, or on with the doors.
Greg
YycXJS (11-12-2013)
Just to add to Vee and Greg's comments.
The switch nearest the driver controls only the front passenger courtesy light. All four courtesy lights should come on when the door is open. (and map lights too if set)
The second switch indeed only controls the rear courtesy lights. They have a sometimes overlooked feature in that they can be swiveled up and down which causes the lights to turn on or off. Before you open up in search of a bad bulb, make sure one of them isn't in the middle position which is off when the switch is pressed.
Also, no dome lights on a conv but we do have map lights in the sun visors which can also be turned on or off manually and set to come on when the door is open.
YycXJS (11-12-2013)
Received 10,979 Likes
Yes, chrome and all comes out. It is held in by two round metal 'points', one at the center of each end. One of them is spring loaded. Try prying out on one end with moderate force. If that end does not dislodge and come out, switch to the other side and try.
Good luck!
Good luck!
BrentGardner
28
04-26-2024 03:08 AM
Tony K
03-26-2024 01:53 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
