XJS Rear Suspension Measurements
Hi I am welding an area on my 89 XJS that looks like it has had a couple of bodged repairs. Consequently I need to know what teh distance is between teh two bolts where the radius arms mount to the body near the two jacking points. Its just teh distance apart - I am happy I know the distance from teh bulkhead.
Alternatively a bodywork diagram with key measurements on it would be good
kind regards
Mark
kind regards
Mark
I just measured mine from the outside edge of each bolt and the measurement was 44 3/4". Full disclosure, I re-welded one of the radius arm mounts.
On my parts car, appears to be original, the measurement is 45" from the outside of each bolt edge (instead of center to center, outer edge to outer edge)
orangeblossom
01-14-2017 09:03 AM
