xjs right front wheel "tilted"
It has been bothering me for a while so thought I would check with everyone. My right front wheel is tilted out at the bottom, probably about 10 to 15 degrees and looks "funny" when on my lift. The tire does not seem to be wearing oddly, but they are less than 600 miles..... What do you think I could do to correct this ???
thanks,
ken in wild and wonderful WV...... by golly !!!
thanks,
Received 10,872 Likes
Received 6,327 Likes
Take it to a tyre shop and get them to do wheel alignment, if the alignment needs adjusting it is a simple fix. If something is worn or damaged they will be able to pin point the problem and give you a solution(quote) to fix the problem.
When it comes to steering and front suspension I always get professional advice before attempting any repair.
Finally found a place that could provide an alignment. They did a great job and got the tires back into a "reasonable" resemblance of the specs. The negative camber on the right front did not move completely back to within specs, but is within .25 degrees. The owner indicated that the tires should wear "pretty close to properly". Time will tell !!
Thanks for all of the comments.
Ken
Ken
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
