xjs shocks
https://www.welshent.com/Jaguar-Shoc...oge-P1886.aspx
I recently replaced the rear springs and shocks with Boges that I bought from Welsh Enterprises.
The old assembly had spacers at the bottom of the spring where it engages the shock (circled in red below).
On the new shocks, the indent that traps the ring that holds the spring in place looked like it was higher up on the shock (circled in yellow). So I assembled the unit without the spacers and confirmed that the length of the spring “at rest” in the shock was the same as with the originals.
Note that there are spacers in the top mount of the shocks where they attach to the cage that are not included in the kit from Welsh. So I re-used these off the old shocks.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
I can't find anything about the install of these kyb shocks. People have installed them but don't mention if any of the old hardware is used except for the small insert that goes in the top eye
