XJS starts and then dies
My 1986 V12 XJS will start up fine and run fine for about thirty seconds to a minute before dying out by what seems like stalling. I have replaced the inlet regulator and all 12 spark plugs, as well as bought a new fuel filter and fuel pump. Beyond this I have no idea what could be causing this issue and I hope someone here might know because I am at a total loss as to where I should look next.
Important as well to replace the outlet FPR (the one on B bank inlet manifold at the front, ie LHS of the engine looking forwards from the cabin). This is the one that controls the injector pressure. The two FPRs are NOT the same and are not interchangeable.
An important question:
When it stops, will it restart? Depending upon this answer, further test can be suggested. Fear not the guys on here will, via you, get it started!
The following 3 users liked this post by Greg in France:
The following 2 users liked this post by Greg in France:
Grant Francis (11-30-2022),
orangeblossom (12-01-2022)
The following 2 users liked this post by Steve M:
cstrad_8 (12-05-2022),
Greg in France (12-02-2022)
Well I messed with it tonight and fuel is not the issue at all. There is spark after I shut it off and now it just refuses to stay running for longer than 30 seconds at a time when it starts
If there is a strong spark at the plugs when it has stalled and will not restart, then fuel is the issue, which is not to say the fuel issue may not be caused by an electrical one in the fuel injection system.
I sugest that you pull one of the front two injectors from the manifold when it has stalled (practice this first, the hoses are long enough to wriggle the injector free without removing the hose). Then with a helper turning the car over on the key and you holding the injector nozzle in a jamjar, (i) see if it is spraying fuel and if not (ii) see if it is clicking, even if not spraying fuel - you should be able to feel if it is clicking.
Received 10,872 Likes
The following 4 users liked this post by Doug:
Grant Francis (12-03-2022),
Greg in France (12-03-2022),
leo_denmark (12-04-2022),
orangeblossom (12-03-2022)
The following 3 users liked this post by cstrad_8:
Well, your next move is obvious. Replace it and post back ! Check the socket while you're there!
The following 2 users liked this post by Doug:
Greg in France (12-04-2022)
I will be going through this weekend and seeing if I can’t clean all of that up and get it somewhat cleaned out. This is also likely contributing to my problem. Thank you for the suggestion.
