XJS strange problem...
Hi!
This is the first problem I've found in my new xjs v12 ... grrrrr!
Well... The car, when in N, is rock hard to move by pushing: I know the car it's heavy iron but... but it's nearly impossible to move!
Note that the car, when engine is running, can move itself and brake.
Any ideas of what's the problem?
Thanks!
Thanks!
Make sure the handbrake is off. Just because it is down doesn't mean it's off. If you can pull it up with no effort and without hearing any clicks, the handbrake is on and needs to be released by pressing the button at the end of the grip and lowering the handbrake.
If the brake is off, the handbrake drums may still be engaged. This is common, especially in cars that have sat for a long time.
Scoupe89 (11-04-2013)
You will not be able to do this with the rear if you an LSD you will need both rear wheels off the deck at the same time.
PlatinumJag
20
10-02-2020 02:23 PM
JagBrian
09-21-2015 07:17 PM
