XJS Sump Tank Drain Plug?
Quick question for the brains trust; Is the sump tank magnetic drain plug supposed to have some form of gasket or O ring? Mine didn’t when I removed it and there isn’t one shown in the parts manual (but maybe that forms an integral part of the drain plug).
Interestingly it didn’t leak, so is it safe to assume it is simply a precision metal to metal seal?
Cheers;
Cheers;
Sump tank. Is that the oil sump or the fuel sump? I think the small fuel tank is more often called the surge tank, but I've seen it called both.
For the fuel tank, the drain unscrews but I've never had it all the way out. I think its a fairly normal fluid drain, as you'd find on a radiator or similar.
For the oil pan. Mine has a copper gasket. I think its 16mm ID, but I'm not certain.
Thanks;
csbush (01-08-2022)
BKSinAZ
03-09-2015 04:09 PM
gtmaster303
09-14-2014 08:02 AM
