XJS THM400 transmission kickdown switch modification.
I did a little modification to my transmission kickdown switch and I am pretty happy with the results. Instead of the switch not activating until after you reach wide open throttle, it now activated at about 3/4 throttle. I am pretty happy with the results. All I had to do was to move the switch from the bottom of the plate on the throttle cable, to the top of the plate, drill 2 new holes, and adjust the switch, and mounting plate to contact the throttle rod.
Doug (03-10-2021)
Received 10,979 Likes
Greg in France (03-12-2021)
bullittandy
09-08-2016 02:31 PM
