XJS V12 Engine Caught Fire....A Word To The Wise!
Old 11-12-2017, 11:53 AM
Anglicomarine0326's Avatar
Originally Posted by Jagboi64
I've drawn a red line around the heat shield.
Here is what it should look like:
Thank you, is it easily corrected? Funny think is, I've never tried the cruise control, but as long its being worked kn, I'll have my Jaguar mechanic correct it.
Old 11-12-2017, 11:55 AM
Also, while it's apart I'm going to have the spark plugs replaced. Any recommendations for plugs (brand) or specific type?
Old 11-12-2017, 12:18 PM
Jagboi64's Avatar
Received 3,169 Likes on 2,094 Posts
It's easy to correct. Undo 2 bolts, flip it over and bolt it back in place.
Plugs: NGK BR7EF. Gap to 0.025" The front 4 are tricky to do, but the quickest and easiest way is to remove the belt on the AC compressor, unbolt the compressor and move it aside. There is enough flex in the hoses to allow this without discharging the refrigerant.
You'll have to remove the cruise bellows to remove the AC compressor, so it's a good time to correct it.
