XJS v12 motor won't turn over
Hey everyone....need some direction on troubleshooting this issue. My XJS V12 recently had a full tune up done about just over 5 weeks ago. Ran like a stallion, super smooth, etc. It then sat in my garage for a month without driving. Now the car won't start!
Radio turns on and the door locks work so I'm not 100% convinced its the battery. When I had the tune up done, I had the mechanics check the alternator and they said it was perfectly fine. All the spark plugs were changed, etc.
Only the gas gauge seems to move when i try to turn the key over. I also hear a mechanical clicking noise when i turn the key. I've tried pumping the gas pedal in hopes that the fuel pump will lend a helping hand. I've also sanded down the contacts on the battery to make sure the battery cables were making good contact.
Any ideas/suggestions???
thanks!
thanks!
Received 10,873 Likes
Just to make absolutely sure we're on the same page, by "won't start" you mean the starter doesn't operate, correct?
I'll assume that's the case.
Even a weak-ish battery will operate those things. Operating the starter takes real oomph! :-). I agree taht the battery should be a prime suspect. Charge it for a few hours and see if anything changes
That won't do anything to help the starter operate :-)
Good, because often loose/dirty cables are the problem
Yeah, make *sure* the battery isn't the culprit before looking at more complex fixes
wont turn over: the engine literally wont turn at all. 0 movement of the engine in a clockwise fashion viewed from the front of the car.
diagnosis: starter or battery
wont start: the engine will turn in a clockwise direction viewed from the front of the car, cranking over and over with no ignition.
diagnosis: multiple things could be at fault but the starter and battery are good.
ive had batterys that were in good condition and perfectly capable of starting any one or probably even several of my supercharged V6's at the same time, but wouldnt crank over the 11:1 compression 12 cylinder if i was pointing a gun at it. lol
lots of rotating mass + 12(lots of compression) = difficult.
"Won't turn over" has confused everyone for years. Most use it to describe a starter motor that isn't turning the engine. However, enough people use it to describe any "no start" condition that clarification is often required.
My Dad was one of those who would say "the engine won't turn over" even though the starter was spinning the engine like crazy....but the engine wouldn't start.
In the repair business these two terms were used almost universally to eliminate the confusion:
"Cranks, won't start"
(Starter operates; engine won't start)
and
"No crank, no start"
(Starter does not operate; engine won't start)
and
M90power (09-02-2012)
Um....er....sorry to have to say this but this bit where you jump into every thread with your "I have a xxxx for sale" is getting pretty old.
We all know you're parting out an XJS. We seriously don't need multiple daily sales pitches :-)
and since i cant post a thread in the XJS section, and the parting out thread is banished to the basement of the classifieds, im going to keep posting the parts that are relative to the thread and the OP's issues.
Start by checking the battery. Put a voltmeter across the leads and read the voltage when you try to crank the engine.If it is below 10 volt you need a battery to begin with. You said it sat for a month or so which leads me to believe you just need a battery or at least a charge.
M90 now is the time to offer your battery for sale.
@Jagvilly
Glad you are up and running again. If your XJS is not your daily driver and it is left for long periods, you may want to consider getting one of these....
This keeps the battery topped up even over long periods of time. There is a nifty connector included that you permanently connect to the battery, then all you need to do is connect the quick connect to the device, ie you don't have to disconnect the battery
Great tip, Sarc...thanks! I probably drive the XJS about 15-20 miles a month, if that. Right now it is running smoother than butter and as cool as a cucumber. My biggest issues are still figuring out why my right/front turn signal blinks like its on speed and taking my doors apart so i can see why my windows stop a half inch from completely closing.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
