XJS V12 need tips for running hot
The biggest one is having the correct thermostats. As Grant explains in this post: https://www.jaguarforums.com/forum/x...2/#post1302110 most thermostats don`t have a long enough `foot`to block off the bypass, so a large percentage of the coolant never goes through the radiator. If you can`t find the Dayco, a Gates 33188S will work, but you need to drill a small bleed hole in the flange.
The other big thing on V12`s is the space between the radiator and condenser seems to be a magnet for debris - leaves, aspen fluff, cat fur, you name it. I have pulled all sorts of stuff out of the radiator that was blocking the airflow. Unfortunately, radiator out is the only proper way to do that and clean the radiator.
The following 2 users liked this post by Jagboi64:
Grant Francis (06-18-2019),
ronbros (06-18-2019)
These are the items to replace/service to get the car running correctly (mostly already mentioned above) but you would be best to do the lot and have done with it:
Which model do you have, by the way?
- Remove rad and clean rad fins and blow out the condenser and oil cooler fins with compressed air
- renew all coolant hoses
- renew thermostats
- renew pressure caps
- remove LHS front wheelarch rear stone baffle and check overflow bottle is intact and the pipe to the wing tank is clear and properly attached
- check mechanical fan clutch and renew if deteriorated
- fill with good quality antifreeze
- renew all drive belts most notably the waterpump one.
- Bleed the system carefully (you can search on here for how to do that)
Doug (06-19-2019)
Good list and I certainly agree with the "do it all" approach to V12 cooling systems.
But, as long as the radiator is out, and since removing it isn't a 15-minute thing, I'd assume it's internally clogged and send it to a radiator shop for a professional boil-out and pressure testing. Might as well go all the way !
The following 2 users liked this post by Doug:
Greg in France (06-19-2019),
ronbros (06-19-2019)
Grant Francis (06-22-2019)
kevo
09-08-2015 09:45 AM
