Xjs v12 park brake fail
I have a 90 xjs just bought. To out there the top down I engaged the parking brake. Too went down. Then up. Now the parking brake will not disengage. I tried playing w the handle. Driving it slow back and forth. But it won't release and the light is still on. Please help?!
On my 83, you have to pull the handle up gently then while up push the little button in on top of the handle and lift a little more, you should feel it disengage and then while keeping the button pressed in you lower the handle all the way down. your light switch could be a bit dicky but you should definitly have the brakes off.
a common issue for new owners
the handbrake ( park brake ) handle is designed to drop after the application of the brake, this is so it does not get in the way for getting in and out of the car,
application is as described by katoh , pull up the handle to take the load, push the button and drop the handle , the park light should now go out
another issue resulting from this is that the park brake pads get damaged or ripped out buy moving the car with the brake applied , so check out this park brake pads
enjoy your new car
BB
ps, there is a genuine window sticker for the explanation of this operation that goes in the drivers door quarter light , usually missing from cars these days,
enjoy your new car
BB
enjoy your new car
BB
enjoy your new car
BB
That did not work. I only driven it like 3 feet so I doubt I damaged it. What is my next option. I can't drive it so can't really take it to the shop. Don't want to drag it onto a tow truck. Thank you for the help.
Also there is no load when I pull up like a normal e brake. It just goes up easy. The button is also inside until it gets to top. The wire under the brake is tight though.
If the handle is lifting with no load and the cable is tight, the problem must be the at the handle end of the mechanism. Lift the carpet at the inside sill area and release the nuts securing the outer cable until tension is released. Maybe the pawl is stuck in the ratchet or similar problem.
Good luck
MC36
US Lower Atlantic
09-01-2015 07:34 PM
