ZF rack centering
Grant Francis (11-14-2019)
Scott
The ZF rack has a small grubscrew which takes a 4mm allen key. It is just towards the centre of the rack an inch or two from the tower. Undo the screw and push in a 2mm diameter probe and you will feel it go into a fairly shallow indentation as the rack centres.
Having said all that, at my laser alignment place locally, the standard procedure is the turn the rack fully one way, and them fully the other, and then the machine tell you when it is centred as you turn it back. This gave exactly the same point as the probe did!
The following 4 users liked this post by Greg in France:
