2008 Spare Tire for 2008 Portfolio
Old 08-09-2011, 10:12 AM
dd823's Avatar
Default 2008 Spare Tire for 2008 Portfolio
Is there anyway to have a spare tire for the Portfolio the wheels are 20"
Old 08-09-2011, 03:08 PM
fstick09's Avatar
No. It's not the size of the wheels that prevent it, but the brake calipers.
Old 08-09-2011, 03:10 PM
dd823's Avatar
could I buy an extra Portfolio wheel ??
Old 08-09-2011, 03:25 PM
fstick09's Avatar
The front and back are different sizes so it would be highly impractical.
This is all assuming your Portfolio has the Alcon brakes. You should have a Jaguar fix-a-flat/inflation tool in the back in case of emergency. Not a very good solution I know, but I guess that is the price for having the El Presidente of XKRs.
Old 08-09-2011, 03:34 PM
dd823's Avatar
Yes mine does have the Alcon Brakes. Hey!! I do have AAA.
Old 08-12-2011, 10:51 PM
Stuart S's Avatar
Received 6,376 Likes on 3,493 Posts
My 2009 XKR Portfolio cvt has Alcon brakes and I previously posted the same concerns. Forget using a full-size 20" wheel/tire as a spare - it won't fit in the trunk well, which is smaller than the diameter of the mounted tire. That's why Jaguar uses a compact/temporary (donut) spare with the non-Alcon XKRs.
One possibility that might work is to use the OEM compact spare (since it will fit in the trunk well) together with a hub spacer (if you can find the right one) that will move that narrow donut spare out enough so it clears the caliper (and not rub the fender), and use longer extended lug nuts (due to the spacer). Because this setup is not DOT-approved, Jaguar won't help due to legal liability issues.
Another (expensive) possibility is to switch to run-flat tires; unfortunately, at the present time, it appears that there aren't any! I checked TireRack.com and they didn't list any run-flats in the OEM sizes; but you might be able to use run-flats that are slightly wider/narrower from the OEM tire that would work with the the Selena wheels.
Like yourself, I concluded that the most practical solution is to call AAA if necessary...and keep a bible in the trunk and pray you never get a flat!
Panthro (02-14-2016)
Old 10-26-2012, 12:43 AM
Stuart S's Avatar
Default Solved!
dd823,
The black 19" spare wheel and compact spare tire from the XJ Supersport will fit on the front without modification but you'll need a 7mm spacer for the rear to clear the caliper. For details, see https://www.jaguarforums.com/forum/x...-brakes-67260/
Works for me!
Stuart
Rivguy
12-04-2020 07:55 AM
perfectson
11-01-2015 10:46 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
Dz1rfj
09-16-2015 03:44 PM
Quebecjag
09-10-2015 06:06 AM
Quick Reply: 2008 Spare Tire for 2008 Portfolio
