2009 XKR Portfolio Brakes
2009 Jaguar XKR Portfolio Details
My 2009 XKR Portfolio convertible has the following options: adaptive cruise ($2,300), Alcon brakes ($5,000), black soft top, rich oak veneer, ivory/slate upholstery ($1,000). Here's a close-up of the wheel/rotor/caliper:
Unfortunately, a spare wheel/tire was not available with the Alcon brake option due to the oversized front 6-piston caliper. Instead, you get a can of "fix-a-flat" and a 12v tire pump. The 20" Selena wheels are not compatible with run-flat tires. I keep a bible in the trunk and pray that I don't get a flat. So far, so good!
Correction: Depending on the run-flat tire, Selena wheels may be compatible. Unfortunately, at the present time, TireRack.com does not list any run-flats in OEM sizes. So you may have to increase/decrease tire width slightly to find a run-flat that might work.
Update: Compact Spare is available - see this link: https://www.jaguarforums.com/forum/x...-brakes-67260/
Last edited by Stuart S; 02-28-2013 at 06:02 PM. Reason: Correction re: runflat tires and Selena wheels. Update for compact spare now available
Panthro (02-14-2016)
Alcon brakes
Interesting. I just got a 2009 Portfolio, advertised with Alcon R brakes and now I have read this thread, I am sure they are not. They are not red like in the photo in the post, the calipers are cast metal with a small red/green logo on - same colour as the XKR but funny. they dont look like an X a K or an R.
That said, I am not sure whether it is a good thing, there is a spare tire in the trunk so I don't need the bible and I am sure the non Alcon brakes are much less costly to repair / replace ?
I checked the link but could not see where they were options - would be interested to double check and make sure they have not been replaced, the car has 30K miles. If you could send the link showing the options.
Become a member to TOPIX and log in here:
http://topix.jaguar.jlrext.com/topix/vehicle/lookupForm
When you enter your VIN all your vehicle details will be brought up and you can see all the options your vehicle was originally fitted with at time of sale as new.
Topix Model X150 /XK
TOPIx - TOPIx
TOPIx - TOPIx
Mike,
Unfortunately, most of us can't join Topix. Jaguar's terms and conditions of registration and use provide, in part:
"Registration
The following conditions must be met:
Then select English and click on United States (for us Yanks) and then click Select.
Next, click the "Please Select" dropdown arrow, and then click on:
X150 / XK (X150 is Jaguar's model designation for the 2007-up alloy body XK/XKR).
Next, click on the bottom dropdown box and select your model year and click Find.
Next, click Owner in the upper right corner. The topics available to owners are then listed on the left side highlighted in green. Check them all out.
I use the online Owners Handbook often, since it is much faster and easier to use than the hard copy version in my car.
I had them fitted because my brakes squealed a lot when braking gently from say 10 mph to 0. The new pads helped a bit but didn't completely eliminate it.
He's very knowledgeable about Jags and according to him such noises are to be expected with such big brakes and can't really be avoided. Seems odd to me though that Jag would be OK with that. Does anyone else with Alcons also experience loudly squeaking brakes under gentle braking like when rolling up to a red light or anything similar?
Mike V (05-28-2013)
Quebecjag
09-10-2015 06:06 AM
