Back up Light '07 XKR
The following 2 users liked this post by H20boy:
Chaos236 (08-25-2011),
ferraripete (09-21-2015)
http://www.ownerinfo.jaguar.com/extfree2viewjagprod/servlet/peachviewfile?t=1287440671356/index.htm
"Depending on market, the single rear fog lamp is located on either the rear left-hand or right-hand side of the vehicle.The rear fog lamp can only be switched on if the low beamheadlamps are on or if the side lamps and front fog lamps are switched on. Press the switch to turn on the rear fog lamp. Pressing the switch again will turn off the rear fog lamp.
Note: Both front and rear fog lamps will be turned off when the ignition is turned off,but will not be illuminated when the ignition is turned on again. The rear fog lamp should only be used when visibility is severely restricted by fog."
I'm so glad I found this post. Just had the car in for service today and as my wife was pulling out while I was paying I looked out to see that (what I thought) was a reverse light out. After figuring out how to get it out I kind of cursed when I realized it was a sealed unit and that I'd have to buy it from Jag. Thanks again Jaguar Forums for the excellent knowledge base!
I am a less than 30 day owner of 2008 CPO XK conv and my wife noticed early on one of the reverse lights was out (as well as an amber front parking light). When I expressed dismay on this forum about two lights being out on such a new car I luckily was advised by a member about the reverse lights. So I only needed one bulb replaced (at no charge).
Jay
Jay
