How to remove center console wood trim pieces?
Old 02-05-2014, 05:11 PM
jahummer's Avatar
Received 2,378 Likes on 1,488 Posts
Default How to remove center console wood trim pieces?
Changing interior wood trim panels and haven't had any success removing the the center console, shifter surround & ashtray cover with out fear of breakage.
Anyone know how to do this? Thanks.
Old 02-05-2014, 05:50 PM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
The wooden trim panel is held in by 8 clips - 3 down each side, 1 just inboard of each of the two switches. It looks like it would be easiest to start at the rear of the panel. Unfortunately, the manual just says "Carefully release the 8 clips".
The following 2 users liked this post by Ngarara:
jahummer (02-05-2014), MaximA (04-01-2014)
Old 02-05-2014, 05:51 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
Have you seen the attached?
File Type: pdf
The following 2 users liked this post by u102768:
Boga (08-22-2019), jahummer (02-05-2014)
Old 02-05-2014, 05:54 PM
Ngarara's Avatar
That's for the 5.0, but the clips are in the same place.
Old 02-05-2014, 06:08 PM
jahummer's Avatar
Perfect, that's exactly what I needed!
Old 02-05-2014, 08:06 PM
BruceTheQuail's Avatar
Received 1,297 Likes on 893 Posts
I bought a trim removal kit from the autoshop (plastic pieces, probably $15 or so) which was useful for some bits. But the centre console itself has a very tight fit, so I found the best thing for that was to slip in a butter knife, and lever it up very gently.
Old 02-05-2014, 08:23 PM
Gray XK's Avatar
Be very careful. I stared at the back using a plastic puddy knife, gently prying up and slowly moving forward. It's a bit easier if you remove the ash tray cover and the piece that surrounds the nav screen first.
Old 02-05-2014, 09:29 PM
jahummer's Avatar
I have trim removal tools, so everything came out perfectly! Thanks everyone.
Old 02-05-2014, 09:37 PM
ct6978's Avatar
Anyone else find the "throw your old part in the trash" graphic funny?
Old 02-06-2014, 05:02 AM
Ngarara's Avatar
Yeah :-) - no eBaying the old bits, you hear?
Old 04-01-2014, 02:15 PM
U2vertigo1's Avatar
Default Trim Removal Roadblock!
I am stuck, I cannot seem to get the Ashtray Veneer to Slide off. The graphic shows holding the Black plastic underside steady with a Screwdriver while having it 1/4 way open and Sliding the top veneer off. How much force do you need to slide it off? Feels like I will break the whole assembly.
Old 04-01-2014, 02:19 PM
jahummer's Avatar
That is exactly how I did it and it came off relatively easily. You are pulling it towards you?
Old 04-01-2014, 02:22 PM
U2vertigo1's Avatar
Yes, thanks. Pulling it towards me. Its just the veneer that slides off correct?
If i hold with the screwdriver tool on the left the whole assembly seems to want to twist and I'll damage it. It does not appear to want to come off.
Old 04-01-2014, 02:56 PM
jahummer's Avatar
There are 4 tabs. Here is a pic of mine flipped over, maybe that will help.
Attached Thumbnails How to remove center console wood trim pieces?-%24_57.jpg
The following 2 users liked this post by jahummer:
MaximA (04-01-2014), U2vertigo1 (04-01-2014)
Old 04-01-2014, 03:03 PM
U2vertigo1's Avatar
That's very nice of you! Thanks! I can see the tabs but that sucker is not sliding off! I'll regroup and try again when I'm not so frustrated!
Old 04-01-2014, 03:24 PM
MaximA's Avatar
That manual has been slightly ambiguous today
Old 04-01-2014, 05:42 PM
Ngarara's Avatar
Yeah, I think they tend to assume you already know what you're doing, so it's just a checklist or aide memoire to make sure you don't forget anything. Not as helpful as it could be for us amateurs...
Old 04-01-2014, 05:57 PM
GGG is offline
Received 16,860 Likes on 12,186 Posts
...... I'll regroup and try again when I'm not so frustrated!
1. open the Ashtray approximately as far as the blue arrow.
2. put your screwdriver on the corner of the black plastic subframe arrowed in red
3. holding the subframe back with the screwdriver, pull the lid forwards using the handle arrowed in green
It should release without much force.
Attached Thumbnails How to remove center console wood trim pieces?-veneer.jpg
MaximA (04-02-2014)
Old 04-01-2014, 08:19 PM
U2vertigo1's Avatar
Thanks Graham! Thats what i did and not sliding off. I wonder if it got glued down by the previous owner...!
Old 04-02-2014, 06:00 AM
GGG is offline
I suppose that's quite possible if one of more of the four plastic locating pegs on the underside of the ashtray lid have been broken.
Attached Thumbnails How to remove center console wood trim pieces?-veneer_2.jpg
U2vertigo1 (04-03-2014)
Quick Reply: How to remove center console wood trim pieces?
