iPod connectivity for $120.00 and 2 hrs labor!
Old 01-21-2013, 09:05 PM
DenverDDS's Avatar
Default iPod connectivity for $120.00 and 2 hrs labor!
I purchased my 07 Jag XK two months ago. My only disappointment has been the inability to connect my iPod. I have searched this and other forums for a solution. Most were either expensive or of poor quality. I purchased an iSimple model IS77 WIRED FM modulator and 2 antenna wire adaptors for a total of 120.00. You could probably find them cheaper on line. With average mechanical skills the installation can be accomplished in about 2 hours. It took me longer as I took a lot of pictures.
Start by removing the spare tire access cover and the rear plastic trim piece held by 4 torx head bolts (T-30). The passenger side panel is held by 2 “push bolts” and has one electric connection to a courtesy light.
Inside the car the passenger side rear seat bottom can be removed by lifting the front edge up. The center section is also removed by lifting up. Then the plastic trim piece just behind the console can be removed. Lift the rear edge up and pull backwards.
Then route the iPod cable as indicated by the red arrow into the rear seat area. A coat hanger wire may help.
Next remove the rubber mat floor of the console. You will see square shaped holes which allow you to route the cables. I used a coat hanger to fish wires through.
I installed the switch on the front of the console. It requires a hole slightly larger than ˝ inch. I drilled a ˝ hole and enlarged it with a dremel tool. Make SURE you drill the hole about 1 ˝ inches below the upper edge. This allows room to route the cable through the hole and have room to push the switch in to place.
The switch wires need to be lengthened by about 2 feet. I cut and soldered wire in the middle and heat shrunk the connections. This gives you enough length to route the wires back into the trunk area. A coat hanger helps fish the wires through.
Next we will use the antenna wire adaptors to convert the factory fittings to “old style”male/female connectors. First locate the antenna wire and separate the connection by pushing down on the ridged area seen next to my fingernail.
Here are the adaptors connected to the factory antenna wires. Now the adaptor ends can connect to the main harness of the iSimple device.
Next we need to provide power and ground. The lower brown/white wire in the antenna assembly is a hot 12 volt wire. I carefully stripped back some of the insulation and soldered the red wire to it. Then tape the connection.
The ground is right next to the antenna assembly. I soldered an eyelet to the black ground wire and shared the ground with the antenna (13mm nut)
I mounted the unit in the space next to the Navigation DVD unit using Velcro. Then button everything up with zip ties to the factory harness to prevent rattles. Final install looks “factory”.
I selected 89.7 on the module and set one of my presets for this frequency. There is a red sticker on the module warning you that you may need to tune in the module but I didn’t need to. I am no Audiophile but the music sounds great to me!! I tried to keep this brief but I have lots more pictures. If something is not clear please ask.
Attached Thumbnails iPod connectivity for 0.00 and 2 hrs labor!-11a_zpsec4094eb.jpg   iPod connectivity for 0.00 and 2 hrs labor!-15_zps04efa32b.jpg   iPod connectivity for 0.00 and 2 hrs labor!-16_zpse0721088.jpg   iPod connectivity for 0.00 and 2 hrs labor!-17_zps7208117d.jpg   iPod connectivity for 0.00 and 2 hrs labor!-18_zps3f296fad.jpg
iPod connectivity for 0.00 and 2 hrs labor!-21_zpsa9b19f9e.jpg   iPod connectivity for 0.00 and 2 hrs labor!-20_zpse1096c33.jpg   iPod connectivity for 0.00 and 2 hrs labor!-22_zps6296a26d.jpg   iPod connectivity for 0.00 and 2 hrs labor!-7_zpscc53dcc7.jpg   iPod connectivity for 0.00 and 2 hrs labor!-6_zps2991d1b9.jpg
iPod connectivity for 0.00 and 2 hrs labor!-8_zps15a113f7.jpg   iPod connectivity for 0.00 and 2 hrs labor!-10_zps80111216.jpg   iPod connectivity for 0.00 and 2 hrs labor!-25_zps3401503f.jpg   iPod connectivity for 0.00 and 2 hrs labor!-26_zps36efcd38.jpg   iPod connectivity for 0.00 and 2 hrs labor!-27_zpsec6f3f97.jpg
iPod connectivity for 0.00 and 2 hrs labor!-28_zps82eab72d.jpg   iPod connectivity for 0.00 and 2 hrs labor!-29_zps1b3a38fe.jpg
The following 7 users liked this post by DenverDDS:
amcdonal86 (01-21-2013), CleverName (05-17-2013), Hailers (01-31-2013), jchou (10-11-2013), mij86 (02-17-2018), u102768 (01-21-2013), WhiteXKR (01-21-2013) and 2 others liked this post. (Show less...)
Old 01-21-2013, 09:14 PM
WhiteXKR's Avatar
Received 2,988 Likes on 2,125 Posts
Good post!
A quality WIRED FM modulator like this can give surprisingly good audio results...not quite as good as the ACM, but very acceptable.
DenverDDS (01-21-2013)
Old 01-24-2013, 03:02 AM
cft080's Avatar
Thank You. Will being doing this Mod to my 07 XK soon...when I get the time.
Attached Thumbnails iPod connectivity for 0.00 and 2 hrs labor!-img_0329.jpg
Old 01-31-2013, 05:40 PM
Hailers's Avatar
I installed this today and it works Great. About $60 bucks for the ISimple from Amazon and I had one of the antenna adapters but had to buy the other from Best Buy for $19.00 'cause I wanted it today not next week.
NO static at all. Much better than that Belkin outfit I tried before this. No comparison at all b/t the two.
Old 05-17-2013, 08:07 AM
Jester13's Avatar
Hi DenverDDS,
I don't suppose you've got any pictures a little wider than those that are so close... I get a bit confused at the part where you start connecting the antenna - I'm not sure where you're digging around at that point!
Thanks in advance!
Old 05-20-2013, 10:22 AM
Ajohnsonnefn's Avatar
I installed this as well and love it except the volume is very low compared to other sources. Anyone else experience this?
Old 10-06-2013, 11:58 AM
Hailers's Avatar
AJOHNSONNEFN.............Yes, I noticed a lower volume and the volume seems to vary bt recordings. I bought Sirrius to make up for it and use Sirrius for most all now except some favorite CD's I have.
Old 10-11-2013, 02:36 PM
BigFern_28's Avatar
Any of you gentlemen live in California? Los Angeles area?? that might come do mine for some $$$ and some cold ones??
42Ajd
12-30-2015 09:45 AM
Poet
10-06-2015 09:40 PM
pk4144
09-24-2015 08:29 PM
hoodun
09-23-2015 12:17 PM
42Ajd
09-21-2015 07:37 PM
Quick Reply: iPod connectivity for $120.00 and 2 hrs labor!
