Portable Audio Interface and iPod Nano 6G
I'm considering buying an iPod Nano (6th Generation, newest model) to use in my 2009 XKR Portfolio. According to the Owners Handbook,
"The portable audio interface supports all iPod generations available at time of writing, including the 3rd & 4th generation, iPod Photo, iPod nano and the 5th generation models." ... "If you are connecting an iPod or mass storage device, you can use the touch-screen to operate and search the device. Many of the controls are similar to those available for CD play." See this link:
http://topix.jaguar.jlrext.com/topix...d=368&id=70644?
If clicking the above link doesn't work, copy and paste this into your browser:
This will bring up the Owners Handbook cover page. Enlarge to full screen view and use the slider bar on the left side of the page to scroll down to Portable Audio.
I'm not sure the 6th Generation iPod Nano is fully compatible with my car, since the Handbook was printed before the 6th Gen was introduced. If you have a 2009 and up model year XK with the factory iPod connector and are using a 6th Generation iPod Nano, how well does the Nav touchscreen work to control the operations of the Nano? For all the Nav touchscreen functions to work, must all the music be downloaded from iTunes or will the touchscreen work with non-iTunes MP3 files? Thanks for your comments.
Yus (09-02-2021)
Answering my own question:
Rather than taking a chance that the newest Nano (6th Generation) would work, I decided to buy a refurbished 8GB 5th Generation iPod Nano from Apple's website for $99. The 5th Gen iPod Nano is recognized automatically when you use the Jaguar factory-supplied iPod cable, and you can control the iPod from the touch screen. I am very pleased with the sound quality.
The following 2 users liked this post by Stuart S:
GordoCatCar (12-20-2017),
Yus (09-02-2021)
Updating my previous posts, my iPod Nano (5th Gen) still works great and I like being able to use the touchscreen to select songs by album, artist, etc. My only complaint is that my iPod doesn't charge while it is playing.
So, I bought an inexpensive charger that plugs into the cigarette lighter but it takes a long time to fully recharge. I'll try my USB charger cable in the USB port and see if that charges any faster.
Does anyone know if Jaguar has an iPod cable that will play/charge (5v output) simultaneously?
Yus (09-02-2021)
I'm using a USB stick plugged into the USB port. The only complaint I have is that for some reason the first second or two of the beginning of each song is cut off as well as the last few seconds.
I may try an iPOD since it can be controlled by the headunit - I'm assuming that will get rid of the issues with the song play.
The separate charging would be a PINTA. Hopefully the USB port plug will charge your iPod Nano. Please let us know if that works.
Yus (09-02-2021)
Stuart
Yus (09-02-2021)
[QUOTE=... Does anyone know if Jaguar has an iPod cable that will play/charge (5v output) simultaneously?[/QUOTE]
Answering my own question!
Starting with the 2010 model year, Jaguar revised the iPod interface cable to enable simultaneous play/charge. That part # is C2P21008 and it is expensive - around $100 from your Jaguar dealer. I was told that it will work on the 2009 XK/XKR models. Not sure if this cable will work with pre-2009 models with the dealer-installed ACM (Audio Connectivity Module).
![](http://farm9.staticflickr.com/8471/8426018914_b148bb8089_z.jpg)
I didn't order it yet. Instead, I ordered a Scosche passPORT charging adapter for $16 from Amazon as a less expensive alternative.
Amazon.com: Scosche passPORT Charging Adapter for iPod and iPhone (Black): MP3 Players & Accessories
I'll let you know if it works.
Stuart
![Amazon.com: Scosche passPORT Charging Adapter for iPod and iPhone (Black): MP3 Players & Accessories](https://www.jaguarforums.com/forum/images/misc/amazon_icon.gif)
Stuart
Mike V (02-18-2013)
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/33926-portable-audio-interface-ipod-nano-6g-8426018914_b148bb8089_z.jpg?dateline=1361163713)
I didn't order it yet. Instead, I ordered a Scosche passPORT charging adapter for $16 from Amazon as a less expensive alternative. Amazon.com: Scosche passPORT Charging Adapter for iPod and iPhone (Black): MP3 Players & Accessories I'll let you know if it works.
Stuart
Stuart
Stuart
I just bought an iPhone cable for my 2012 XKR-S from Amazon, and while my iPhone 5s plays through the head unit, with full controls, it doesn't charge while playing. I saw another member with the same model and year who had this problem with an iPod nano and solved it with a pass through adapter (like the Scosche). I could buy one of these but I am baffled since I have confirmed using a multimeter that the iPhone is getting the requisite 5v from the car via pin 5 of the lightning plug, so it should be charging without any kind of adapter. Any ideas out there? Also, anyone with the same model and year had success with the official Jaguar cable? If so, I'll just go buy one (foolishly thought I could save ~$100!)
Hi.
I am new to this site as I have only recently purchased a Jaguar XKR 2009. Here in NZ we do not have the outlet afforded by America or Europe. I am presently attempting to buy connections for the iPod outlet which will work a I phone 5s on the touch screen controls. Can anyone advise a cable type which is best used for a 2009 model and the best website to purchase from.
Regards
Assure
Regards
Assure
Hi.
Hi Ngarara,
Thank you for your reply.
Yes I do have both of the ports you mention. I have tried to use the USB port using my Iphone 5S and also using a memory stick with various types of down loads from both itunes and microsoft media player. The system does not read these with the message in the folders tab " no music file available" so unfortunate,y I am still having no luck.
Regards
Alan
Regards
Alan
Yus (09-02-2021)
OK, with the iPod, you need to use the Jaguar-supplied 30-pin cable, with an Apple 30-pin-to-Lightning adapter (get the genuine Apple one, some people have had issues with copies). It won't work if you use a Lightning USB cable plugged into the USB port.
I have no experience with using memory sticks, sorry.
Did the Amazon ad specifically state that the cable simultaneously plays and charges? If not, then it probably doesn't. I'd return it and buy the latest version OEM Jaguar cable, unless you want to try the Scosche adapter and see if it works with the cable you bought from Amazon. The Scosche adapter works with the first version OEM cable, but I don't know if it will work with non-OEM cables to simultaneously charge and play.
I ordered a cable through Ebay from a Chinese supplier. It works for either my Iphone 4S or Ipod. I have now left the Ipod hooked into the 12 XK for two weeks and the battery shows a full charge and I use the Ipod on a daily basis. Cost around $38 and arrived in about 6 -7 days.
I hope this information will help others with a similar problem.
Regards
Alan (Assure)
Interesting - the handbook for mine (MY11) says it plays MP3, WMA, WAV and AAC files, with a maximum of 256 GB capacity. I guess the later software is effectively a downgrade!
It should still support iPhones & iPods, though - they use AAC, but the data is decoded by the Apple device and what the car receives is an audio feed.
