"R" caliper decal solution!
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Like many, my "R" decals on the brake calipers were almost invisible. After scouring this board I couldn't find a reasonably priced solution. Didn't make sense to put the same OEM decal on to just wait for it to fade. I like the "R" and found these little jewels:
High Quality R Performance Key Chain
They are almost the exact scale of the caliper decal. Coincidence? With a little work with a dremel I cut off the chain loop. Tin snips to cut the loop and a file work just as well. I carefully cleaned the caliper to remove any oils. I used 3M double sided gel-like super mounting tape. I was waiting to post until I proved durability. They have been on over a month and survived many washes and heat cycles.
They are chromed brass so they won't rust. Gives it a nice 3 dimensional look too. I use heavily diluted Simple Green to clean the wheels.
New set is only $48 for all four!!!
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/86282-r-caliper-decal-solution-bigwheel2_zps57a538fa.jpg?dateline=1401550414)
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/86283-r-caliper-decal-solution-bigwheel1_zps03001ffe.jpg?dateline=1401550414)
The following 2 users liked this post by flyc2c:
Ngarara (05-31-2014),
sherbercars (06-01-2014)
Nice! I was considering the very same but, I thought of using a two-part epoxy glue instead of the double sided tape. There is a lot of heat and vibration at that location and I was concerned that if the relatively heavy piece came off the speed, it could damage the wheel. The part that it is glued onto is a simple, cheap, easy to remove plate that could be replaced if and when needed.
Fly2c2, looks good I was considering the same, concerned about them flying off after awhile. Reason for my post is for those of you considering the "R" check out bay's link............3D XF R Logo Metal for Jaguar XF XFR XK XKR Supercharged Emblem Badge Sticker | eBay
The original caliper decal is closer to 1 inch by 2 inches which is the exact size of the key chain fob.
![Embarrassment](https://www.jaguarforums.com/forum/images/smilies/redface.gif)
The 3M tape I used is good to 300F so it shouldn't come off. I'll post if it fails.
Gato Negro (06-10-2014)
I bought new decals from the eBay seller below. He was SUPER nice and it didn't take that long to get over the pond
SUPERGRAPHICSF1 Brake Decal Sticker Fit Jaguar R Front R with Red Green X1 | eBay
He offers both the Lime Green stripe for newer models and the Dark Green stripe for older models.
I have had them on for over 3 months and live in Texas with stop and go traffic, along with regular car washes and they haven't given out in the least.
mikiep
12-20-2019 07:37 PM
jimforrest (uk)
02-28-2019 06:42 PM
LilaJagHubby
10-06-2015 02:56 AM
