Red center caps on wheels...
My 20" wheels currently have black center wheel caps (first pic).
My 2002 XKR had red center caps, and they added a bit of contrast to the wheels and the black car. The second pic is of the red center cap with the same growler as the one that is currently on my wheels in black.
What do you think? Does this add any "spice"/color (in a good way) to the wheels?
EDIT: I should add that I plan on painting the calipers red at some point - I'm thinking that the red caps would accentuate that look as well.
Received 6,324 Likes
Another possibility is the retro classic script Jaguar center cap that was standard on my 2009 XKR Portfolio:
![](http://farm7.staticflickr.com/6237/6281963298_bfde0381c9_z.jpg)
This would eliminate any concern about conflicting with the grille emblem. I'm pretty sure they're available from your dealer for slightly more than the growler cap.
What are those dots on your rotors are they cross drilled? It appears they don't go through the rotor though. Like your taste in tires.
I've ordered a set of Red center caps.
I hadn't considered the older style center caps. Will think about this more.
There may be other possibilities here that I have not considered...
My car has the optional Alcon brake package, including larger diameter crescent-drilled rotors with 6-piston front and 4-piston rear calipers (I think they're made by Brembo). Drilling goes all the way through. I'm pleased with the Michelin tires.
Stuart S (03-27-2013)
That's what I was thinking but couldn't tell from the pic and crescent drilled rotors are not so common as compd to cross drilled so I did not recognize that pattern; I wonder what the benefits are vs cross? How's the dust with those brakes/pads? Michelins are the best.
Yea, that sounds like the same grill badge I have. I have looked around and can't find any grill badges for later XK/R's that have Red instead of Black.
"Advantage Extreme discs have been engineered to produce optimum bite, thermal stability and durability in an exceptionally high strength to low weight design. This has been achieved by combining a special Alcon developed iron alloy disc with an aerospace specification alloy bell. Other disc benefits:
- Unique crescent grooves on friction faces provide the bite usually associated with drilled discs without the attendant durability problems
- Directional curved cooling vanes for optimum cooling performance
Alcon's floating disc system (as used in the majority of applications) has been designed to allow thermal expansion of the disc throughout its life while minimising the tendency to judder"
See this link for more detailed info about the crescent grooves: http://www.alcon.co.uk/download/know...roovediscs.pdfI was wrong about the crescent going all the way through - they're gooves, not holes. My experience with the Alcon rotors is that they are quiet, smooth and have superb grip. But they're very expensive, so when I approached 30K miles, I had the pads/rotors inspected by my dealer (Nalley - great guys!) and was able to have a simple pad replacement done without turning or replacing the rotors, thereby saving lots of $$$. Bottom line: better to replace the pads before the rotors get scored and too far gone that they need to be replaced.
As for the dust, I think it is not much different from the other OEM Jaguar pads. The dust is a real PITA, so I recently tried waxing the wheels with some very old Maguiar's carnauba paste wax that I had laying around. I think that helped. Now, instead of having to clean the wheels after 3 or 4 days of driving, I can go well over a week and simply hose them off. The wax appears to repel some of the dust and facilitates cleaning.
Stuart
Red center caps with red calipers will look great. Now if you install the red front badge from a 2014 XJR ... that would be mega-cool! I'm just glad to see I'm not the only one suffering from CDO. I know ... most refer to it as OCD but it really should be CDO ... with all the letters in proper, alphabetical order!
Being a reasonably new Jag owner, I don't know the best place to get various Jag accessories, such as red "growler" wheel caps, a red "growler" front badge, a chrome "leaper" for the trunk lid, red calipers or caliper covers, etc. Can I get all of those from my local Jag dealer or is there somewhere else I should look? I looked at CariD but I'm not ready to "Pimp My Ride"! What about a chrome "leaper" on a base for my desk? And what about Jag apparal? My Jag dealer said "Jag quit making it". Thanks for your help.
