$263.73 to change both air filters? (not cabin)
Here we go again with K&N air filters!
See this definitive thread from 2014;
https://www.jaguarforums.com/forum/w...d.php?t=119498
The OEM engine air filter on my 1960 Corvette was foam bathed lightly in oil, similar to today's K&N filter. When I swapped out the original 283/230HP engine in 1965 for a 1965 327/365HP crate engine (WOOHOO!!!) the OEM filter was a paper element. Oiled foam is ancient technology. I learned my lesson after falling for K&N's marketing hype and buying 2 for my 1993 600SL. A waste of money IMHO. A high quality paper filter works better and costs less.
If the K&N oiled foam method was better, manufacturers would have continued to use it after the '60s.
Stuart
Stuart
pk4144 (09-26-2020)
MarkyUK (09-26-2020)
Gotta say for what little it's worth I agree with Stuart on the filters.
I've read pros and cons on the KN, but LOTS of nightmare threads about MAF sensors on these cars. My thinking: stay with the OEM filters . Plus, I feel like I read a comment from Brutal (who's off this group?), pointing out that the sensors ARE tricky, and something about how using not only OEM but MATCHED filter pairs was the way to go. Honestly, I've never had an issue or thrown a code on that and at this point I don't want to start. So I'll pay the crazy price to not have to worry for a few years.
I've had K+N filters for 3 years now. No issues as long as you clean them out every now and then.
There was a P0101 code that always came up, but I was able to pinpoint that to an intake air leak, not the filters, not the MAF sensors.
Also, getting the filters 'checked' has the same labor cost as getting them 'replaced'. There's no way to check them out without doing all the work anyway. Unless they are boroscoping them.
If you plan on doing it again while you own the car, you might as well do it yourself now and learn the procedure.
Cee Jay (09-28-2020)
When I had them checked but not replaced I was not charged.
#28
When I had them checked but not replaced I was not charged. They removed one and said it was OK.
gkubrak (09-28-2020)
#30
I have found the cabin filters on every car I’ve checked to be in need of replacement every year. As for the intake filters, it’s likely environment will determine that. If you drive through a lot of dirt and dust they are going to clog up. Mine were like new after over 50,000 miles done,
#31
#32
#33
#34
$16 and fits your 2010 as well:
The part is C2P2410, and it appears you can do better than that price; $66 here is my to the door price.
https://www.jaguarparts.com/oem-part...UtMGwtdjgtZ2Fz
#35
It’s likely mostly labor. Remove both front wheels, remove front wheel liners, remover filter housing screws and covers, slide out filters and holders, install new filters and reverse.
now if you are doing yourself, you can just do one side at a time and turn the steering away to reveal the front liner, undo the liner screws and fold it back, open the filter house and wiggle the filter assembly out.
#36
80sRule (09-29-2020)
#37
I wouldn't pull them back for risk of having them flop around and get dust/debris into the exposed intake boxes.
#38
For the Cabin Air Filter(also sometimes called the pollen filter on these cars): Yep, super easy. I get a Beck Arnley one on Ebay, about thirty bucks. BUT... if I go get one at a local Jag dealer, it's like forty and change. Who's suggesting that crazy price?
There are two "threads" of advice here, so pay no attention to those talking about "pulling back flaps." Those are for the engine air filters-- totally different operation.
#39
For details, with photos and cabin filter choices, see the "Sticky" in the XK/XKR - 'How To' / DIY Repair & Maintenance FAQ under AirCon:
https://www.jaguarforums.com/forum/x...enance-227403/
P.S. It's another definitive thread, this time from 2013.
guy (09-30-2020)
#40
