07-09 XKR Dynamic Mode Engaged
It's the equivalent of hitting the checkered flag button on the 10+ models. Noticeably stiffer on the highway and much more predictable.
I understand that a lot of the 10+ XKR and XFR owners hit the flag button right when they start driving anyway.
You can just unplug the shock top connector but by unplugging the ADCM no fault codes show up in the dash.
I am fascinated. How do you unplug CATS? Is it a fuse?
That's awfully ironic. I assumed the CATS module was supposed to improve handling. Now I come to find out it's really more for providing a cushy Buick-like ride quality when you aren't driving hard!
The ADCM is what commands the CATS suspension, when active additional solenoids in the shocks are opened, increasing the flow of oils in the shock creating a softer ride. I was on the highway gunning it a couple weeks ago and my front end felt very floaty which made me feel like I didn't have high speed control.
HOW TO: Now to the important part, the ADCM is located behind the passenger side (USA) rear seat, seat back. To get to it you have to first remove the seat cushion (bottom part) by pulling the front edge straight up (two clips will release very easily). Next you have to unscrew a torx bolt you'll find at the bottom of the seat back. Note you'll have to do both sides of the back seats as the seat backs are adjoined with cross support bars. Once you have removed the torx from both seat back sides you can lift them as one, like a bench, just up 2 inches then towards you and their off. Now you will see the fuse box in the center ( the middle back cushion is actually attached to the seat backs cross bars). looking at the fuse box to the left you will see the ADCM. Their are 2 connectors, one for power (small clip), the other for input/output signals (Long clip). They both have push clips in the middle facing you, simply push with one hand and wiggle out to the side (right) with the other.
Once they are disconnected you have basically cut off all communication, the CATS won't activate plus no fault codes b/c the ADCM won't communicate with the CAN Bus.
To some it may sound crazy but on Jaguar Models across the board this is the step everyone takes when installing a non-CATS suspension. It's just a plus that you can make the OEM suspension stiffer this way too.
If you thought removing fuse 19 was a rise, this will really give you a rush.
The easy way to tell is to pop the hood. If the top of the strut (shock) mount has an electrical wire going to the middle of it then yes it does.
I think all X150 2007-2009 have the CATS suspension system as standard but checking the top of the strut mount in the engine bay will tell you for sure.
2 negatives to unplugging the electrical connector at the stru mount are
1. To disconnect the rear strut connectors you have to remove the entire trunk lining and
2. You will get a suspension fault message in the dash as the ADCM will still be communicating with the CAN Bus.
For me, due to the lack of a dynamic button in the 07-09 models this was the only way to transform our "GT Cruisers" to "GT Sports Cars".
I'm sure an auto electronics guy could run and off/on switch maybe from the ADCM Fuse and have control of this from the drivers seat with a mounted switch if desired. Just food for thought, some guys did this with the active exhaust to fuse 19, e.g. installed a switch rather than just remove it.
ray279 (03-20-2024)
I'm going to leave it like this for now but when I start doing some other things in the fall I'll try the fuse route. If it does disengage the ADCM in the same way (off with no warnings lights in the dash) then I'll have my car electrician install a switch so I can maintain the softer ride around town and switch it off once the roads are smooth.
it be cool for 06-09 xkr owners to know if the fuse route works.
