07 soft/spongy brakes - RESOLVED
Old 05-11-2018, 07:07 PM
wkb's Avatar
wkb
wkb is offline
Default 07 soft/spongy brakes - RESOLVED
07 xk with about 82k miles. Newish brake pads and discs. 6 months after brakes replaced brake pedal began to become spongy. Brakes would still lock on hard application. Abs works fine. Blead brakes and pedal returned to normal. Within 2months and 3k miles pedal is again soft. No apparent leaks. Fluid level has not gone down. After braking hard enough to engage abs brake pedal is harder for a stop or two then reverts to sponginess. OEM pads and discs.
Brakes were bled exactly per shop manual.
Has anyone experienced this?
Last edited by GGG; 05-17-2018 at 07:52 AM. Reason: Add 'RESOLVED' to threasd title
Old 05-11-2018, 07:35 PM
steve_k_xk's Avatar
Received 1,548 Likes on 895 Posts
I've had a lot of problems at work using the blue coloured dot 4 specifically the bendix brand , not only does the fluid go dirty very quickly (6months) but I've had to replace to master cylinders due to the rubbers deteriorating.
So check the fluid quality and master cylinder is my advice .
wkb (05-11-2018)
Old 05-11-2018, 08:37 PM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
Sounds like the master cylinder is leaking internally.
Old 05-11-2018, 09:07 PM
Cee Jay's Avatar
Received 5,359 Likes on 3,173 Posts
Even though they were bled, there may be some air or water in the system. Cheapest fix first, replace ALL the brake fluid. That should be done every 2-3 years anyway.
Old 05-17-2018, 02:17 AM
wkb's Avatar
wkb
wkb is offline
Moisture content of brake fluid was less than 1%. Replaces master cylinder and brake performance has been restored. Thanks for pointing me in the right direction.
Old 05-17-2018, 02:30 AM
steve_k_xk's Avatar
Glad we all could help 😁
vdpnyc
07-07-2020 10:10 AM
nickdabs
10-30-2017 06:14 PM
vdpnyc
05-05-2016 06:46 AM
darin from russo
08-27-2014 09:59 AM
bekcon
04-03-2013 12:35 AM
Quick Reply: 07 soft/spongy brakes - RESOLVED
