'07 XK Glove Box Button
Wow, I'm replacing the third one in four years. For no reason the tabs that hold in the housing snap off and the entire assembly launches into the passenger seat. Has anyone had that problem? Would shorting the spring to relieve some tension on the tabs work?
Thanks,
DOC
Thanks,
DOC
Just happened to my 07 vert
Yes. Experienced same phenomenon last month. Discovered spring on passenger seat and gaping hole in glove box. The replacement part is not cheap. I ordered mine online and had the dealer install it while having other work done. Labor time 1 hour as apparently glove box has to be removed. What's next?
