'07 XK NA - this really IS a VERY strange noise...
Received 2,048 Likes
TN,
do the following to save yourself future grief.
Put an amp meter on the battery in a location where you can see it after car has been locked. If you notice a draw on the amps and you hear that same noise it could be some component running when it shouldn't and will eventually drain the battery.
I wish it were one of those two suggestions, but it's not. It's not a mechanical noise at all; too intermittent and irregular for that. The location is quite unmistakably in the brake servo and right-hand bonnet airbag area.
Either it will break one day, and I'll know what it was, or it won't and I won't. The car spent its first nine years supplied in Ireland; perhaps there's a leprechaun trapped behind the dash...
TN
TN
Aha! Forgot you are on the other side of the 'pond'.
Check out this thread in the 'other' Jaguar forum, bet its your problem:
Strange noise from Pedestrian protection airbag unit (?) (2007XKR)
Sean W (07-15-2017)
TN
As soon as the poster mentioned "Geiger counter"., I knew that was it. That describes the sound almost perfectly.
It's the alarm sounder (under the bonnet airbag). My new alarm sounder arrived today; made by Fiamm, in a Jaguar box, but would you believe it has a Mercedes part number on it? The one from a 2015 Sprinter is the same, but half the price!
Admittedly the Jaguar one has an extra bracket attached to it, but it would take at least two minutes to swap the old bracket on to the new horn. Worth every extra cent....NOT!
#30
#31
#33
#34
#35
#37
#39
