07 XK oil Pressure and Water Temp gauges
Hi there, call me old fashioned but I like being able to view oil press and water temp gauges. I just recently purchased an 07 XK - and while I like driving the car, I miss the full instrumentation. Here goes, a few years ago I grafted a dual pillar gauge pod onto an existing stock pillar. After some considerable sanding and recovering it came out reaalllly nice. I was thinking about doing the same for the XK. Thoughts? There are some very nice modern looking digital gauges out there which can then be mounted to the pods. I have never worked on Jags so someone may be able to enlighten me on the difficulty (or ease) of hooking up the sender units…. I will probably leave it to my mechanic…Am I nuts?
Fstbmw1 (03-23-2015)
[QUOTE=Fstbmw1;1189868]Hi there, call me old fashioned but I like being able to view oil press and water temp gauges. I just recently purchased an 07 XK - and while I like driving the car, I miss the full instrumentation.
you would be better off purchasing an oil pressure tranducer that is used in the aircraft industry and tap it into one of the 2 ports on the bottom of the engine.
YOu can thn get the readings thru telemetry to a obd link mx bluetooth and read the oil pressure readings in real time. you can buy it thru any avionics mag. Both raytheon and northrup sell these transducers.
They are more accurate than anything you can purchase for a car
If you do make an A pillar pod that would be a great way of adding a couple gauges. There is absolutely no reason a standard electronic automotive sensored gauge won't work well. The only problem is, with this car it's not "are there any factory locations to plug a sensor in or T into", it is "what all am going to have to take apart to get to those areas?".
Forgot to add. Some people use a Bluetooth OBD tool and the android OS app torque (I think that's what it is called) to monitor these things on their phones since the car does have the sensors already sending info to the ecu. I am about to try it out as well since boost and AFR were there two gauges I added to my previous vehicle and I miss them.
Thanks for the ideas and thoughts. For me, a big part of thinking of a gauge pod set up is that I like to see the information as I drive. I appreciate that it may not be as accurate as some of the 'apps' available but a sporty cruiser as the XK should have come with some gauges. 'jagtoes' I agree, especially for the XK a live voltage meter would also be a nice addition. I am pretty busy on a project at the moment but later on in the year I shall investigate if this crazy idea is feasible or not… from a sending unit 'hook up' perspective.
Have you seen this thread for gauges on the touch screen? https://www.jaguarforums.com/forum/x...nstall-138621/
It might be a logical add-on to the integrated backup camera kit once that is finished.
If I do it, chances are it would leverage existing products, but relayed to the vehicle's touchscreen, so it probably will work with your smartphone.
Not sure if I am doing it yet, but I am thinking about it.
I'm hoping the remote OBD displays (the ones that are primarily for HUD speedos) will get a bit more sophisticated, because I don't want to lose the standard touchscreen display just to get gauges. There are a couple that show engine temp; haven't seen one that does oil pressure yet. I'm hoping one will come along that has more customisation available, then it can compete for dash space with my TomTom, V1 and Road Angel
I was just reading the post on USB Port and looking at post #11 there is a plug and play unit that plugs into the iphone plug and lets you stream your iphone play list into your infotainment unit. Now my simple mind says why can't something simple like this be made to transmit iphone or android app for torque pro into your infotainment unit. I'm thinking out of the box here but when I mention a plug and play gauge kit I envision plugging an adapter into the OBDII outlet and stream BT data to this adapter that is plugged into the iphone cable or stream from OBDII to iphone/tablet and then stream from that to an adapter on the iphone cable which puts the gauges on the screen. It seems simple in my head but I'm assuming it can't be done yet. Is this practical? Just thinking out loud
You can even go wireless. You need to set up a WiFi network inside the car. Then you can use Chromecast to stream the app from your phone to an HDMI to composite video adapter with Chromecast attached, and feed the composite video into the GVIF adapter.
If you use a Kiwi OBDII adapter (https://plxdevices.com/product_info.php?id=GSST2WIFI) you can even add whichever additional sensors you want.
If I do a product, I will bundle the devices together in a package with easy to follow instructions and add some tweaks to make it as seamless as possible.
It actually can be done now. If you do a wired version you need to get a video adapter for your phone and feed the OBDII app. video into a GVIF adapter.
I use an OBD reader and feed the data to My Galaxy S4 where I have loaded in the Torque Pro app. The Galaxy is mounted on the left center air conditioning vent with an inexpensive mount bought off of either Amazon or Ebay (I can't remember which). Since having the phone on all the time chews through the battery very rapidly I connect a power line to the cigarette lighter in the ashtray mounted under the dashboard. It doesn't look prety or built-in, but I get constant temp, battery, and MAF readings as well as rpms and road speed.
I don't use it around town, but I use it on road trips in excess of 100 miles each way. The only problem I have with this method is that sometimes I have difficulty getting the bluetooth communications to work properly. Total cost of solution - under $50.
