07 xk won't start
does it crank ? do any lights go on ? Battery ?
I had a similar problem yesterday when my daily driver ( x type ) wouldn't crank at all after I changed the o2 sensor over the weekend. Ended up being a loose wire on the starter that got jostled when I was moving things around. Sometimes it's those little things ...
gl
gl
What sensors are located in the area you did the work. Did you have to move any wires or connectors or even vacuum lines to replace the hose. Did you do anything else besides replace the hose. It's gotta be somewhere in the area of the work. My 2 cents
Received 1,975 Likes
NO codes. The only sensor I was close to was the one right by the upper radiator hose. I was hitting it quite a bit trying to get the upper radiator hose on but it looks to be in good order. I guess I'll take it all apart to see if anything got hit. I've taken the car apart quite a few times and have never had any issues.
OK I assumed you had maybe a smart charger hooked up while you were doing the fix. If the hood was open then you can't lock the car and the processors will still suck some energy out of the battery. Anytime I do any work whether it be detailing the interior I always keep the charger hooked up just to keep the battery topped. Funny it didn't start even though it turned over. Do you know what the battery voltage was.
Well it was the stupid battery. I charged it after the fact because that's what I initially thought it was. My charger said it was full but I guess because I left the hood up while it was charging it just couldn't get all the way charged. Any way, it's charged and running great. Sorry for posting a dumb question but happy that's all it was.
Glad it worked out cheap and easy for you. And thanks to this thread, we learned some valuable information - always use your battery maintainer when working on your X150.
Do you have an under-hood light? My 2007 does not, and I've left my hood open for more than a week (while waiting for parts and time to work on something under the car), with no ill effect.
On my 2012 it goes like this. Open the door to pull the hood latch and the computers turn on. Open the hood and the computers are still on. Then you can't lock the doors and early shut down the computers when the hood is open. So it's like the car sits without being locked. A marginal battery will lose voltage and will not have enough to start .
Mike Leon
General Tech Help
10-07-2017 05:24 PM
GT42R
07-06-2012 06:44 PM
