07XK NA oil leak
07XK NA oil leak
Hello Jaguar family I drove to work this morning which is a 4-5 minute drive, nothing seemed amiss. Got off work 8.5 hours later, come outside to car see obvious fluid under my car that wasn't there when I arrived. Pulled up slightly, touched the wet spot on ground..oil. Checked the dip stick, there is still oil. My coolant level has dropped slightly but don't feel any leaks on hoses or under header tank.
JaggyBoii (11-17-2023)
I checked the level of the oil and it the dipstick isnt reading that I lost a massive amount at all. I drove home which is about a 4-5 minute drive, checked under car didn't see any oil. Checked about 15 minutes ago still no oil under the car.
steve_k_xk (11-18-2023)
Received 1,177 Likes
JB:
It's a long shot but here's my story. I live in Paradise San Diego California, great weather all year around. Well, a few years ago it got super cold and I didn't leave drive either car, including the Jag. Well it got so cold the seal between the tranny and the pan bagan to leak tranny fluid and I am not talking about Bud-Light! Fortunately, all I had to do was retorque the bolts and problem solved.
Now in your case, maybe you had a few cold nights in Maryland, you only drove 5 minutes, and the tranny seal separated and leaked?
Attached are a few pics of my leak.
Look for oil on each bolt.
Anyone know if this is an original trans pan? (with the big oil drain plug?)
This was the original leak in my garage.
Received 2,048 Likes
JB:
McJag222 (11-18-2023)
