08 XKR foot well padding coming down?
If this is the fiber panel under the glove box it can be a bit of a chore to replace. After wiggling on my back into the foot well I removed mine completely and started all over with it. The front (nearest firewall) must go in first. It goes up above the upper edge of the carpet and must be wiggled around to make it slide into place. I found myself getting burned a little around the foot well light while tucking the edges up into place. Once it slide in though I simply aligned the three clip holes (just under the glove box) and snapped them back in place. When it in correctly it should be tucked flush and not be able to see any bulges or distorted edges. A look in the other foot well would be a good indicator of how it should appear.
If you had not removed those clips before you started, they simply take a little bit of effort to pull them out. Removing them is the only way to get the process of reinstalling the panel started.
There may be others who can shed some light on it as well.
LoudHogRider (05-01-2017)
Received 2,012 Likes
kj07xk (05-01-2017)
Pretty much this. My lovely bride has an annoying habit of crossing her legs in the car, and wound up kicking mine to death. As the slot areas where the tabs are supposed to go are fragile and close to the edge of the panel, mine were torn loose. It was easier (for me) to order a new one and replace it than trying to repair the old one. IIRC, it was around $120 from the dealer. Let me know if you need to part # and I can grab it from the file.
kj07xk (05-01-2017)
Since this thread reminded me to get some of those clips, I did some searching, and it appears that the clips are a Ford part # W709688-S300.
They are available from multiple sources online, with single clip prices being about $0.66 as the lowest. I decided to order from clipsandfasteners.com for a pack of 25 for $7.05 (actually $11.72 with shipping):
https://www.clipsandfasteners.com/Fo...0_p/a21790.htm
I'll update this thread when I get them, to indicate if they are correct or not.
https://www.jaguarlandroverrenoparts...ation-c2p17130
Their price was $150.54, plus $18.67 shipping ($169.21), best price+shipping I could find.
LoudHogRider (05-09-2017)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/pict01_03dd16ad8e0b9d35bf3c97a7dc104cc4bb27fd53.jpg)
Old clip on the left, new one on the right.
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/pict02_25d3ac5ef1951661723414cbfa81b787034fd38d.jpg)
New clips have a bit more 'spring' to them than the old clips, so hopefully hold better.
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/pict03_c591342550644307a397676ca8ea472b51dd06dc.jpg)
Dimensions are identical to the old clips.
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/pict04_a11c9b8cc745cae660fd97eb18f00fc95cfc63da.jpg)
W709688-S300 Says 'Ford 2012 - On', but fits my 2007 XK perfectly.
The following 3 users liked this post by kj07xk:
Just ordered one from Jaguar Land Rover Reno Parts:
