11 XK NA A/C is warm when first started
Had this issue for about 4 months, when I first start the car the a/c is either blowing slightly warm or barely cooling. Drive a couple miles stop and turn off engine then restart and then it blows cold, I am told it is the compressor going bad. But after 4 months think it would have failed by now.
Anyone else have this issue?
Assuming you have no DTC codes, if it's me, I'd clean the Condenser coils and Radiator coils. A lot of dirt can accumulate there. Then assuming I had sufficient refrigerant, the next test to prove out a failing compressor requires the clutches compressor diagnostic tool and as far as I know, the tool is the only way to determine a failing compressor, but I don't have any direct experience with your issue. I would check the compressor before moving on the the evaporator valve.
guy (04-19-2023)
Mine displayed very similar issues, had gas checked , already full and all correct. However, there were issues with pressures in the system.
Turned out to be the valve in the compressor body that controls the pressures between the high and low pipes. £400 all in the get it fixed last year some time. If the valve is not operating correctly the system gets a bit confused about what it's supposed to be doing.
New valve fitted, perfect cold air within seconds of starting the car, and the defrost starting working again to clear the screen on misted mornings.
Have a look at this TSB - https://static.nhtsa.gov/odi/tsbs/20...94594-1020.pdf
This is the part I had replaced on mine when it was taking time to start cooling properly. The symptoms were all like low gas with it only cooling when engine revs were up whilst driving and then becoming warm and moist again when sitting in traffic. My system also wouldn't direct demist/defrost air up the windscreen when first started each day, I'd have to get driving and then after a few hundred yards the vents would open and air would be blown upward to the screen.
It steadily got worse over about a year until I had my air con man come and look , but the system was full, he couldn't get any more a/c gas in. He said there was something weird going on as the high and low pressure pipes were not pressured as he would expect them to be.
I did a load of googling and eventually found a few mentions of the A/C compressor Direct Pressure Sensing (DPS) valve although the symptoms of failure were not consistent; people were seeing different side effects but the one consistent effect was an underperforming A/C when everything obvious had already been checked.
Sager Alanizi
05-22-2021 06:55 PM
ArnoldKay
02-28-2017 03:47 AM
