13MY standard Rear Brake Rewind tool
Can anyone provide the size or pin spacing for rewinding the rear brake caliper.
I tried the AutoZone tool but none fit the spacing. Trying to determine what size to possibly buy a set, but need to know the spacing first. Can seem to find a reference any where.
Thanks,
Dana
Thanks,
Dana
Dana, I bought an inexpensive universal brake caliper set on eBay for my 07 and 12 verts. It didn't fit the pin spacing so I used a grinder and file on the pins to relieve them enough to fit the spacing.
I can't remember the cost but it was something less than $20. After "modifying" the pins it worked great.
I don't know if that helps but it is the best I can offer without shelling out big $$ for a Jag specific tool.
Received 2,626 Likes
If you want to have a proper set of inexpensive brake caliper tools, have a look at this:
https://www.harborfreight.com/disc-b...-pc-63264.html
The following 2 users liked this post by NBCat:
Queen and Country (10-13-2017),
Sean W (10-13-2017)
The electronic parking brake must be released prior to removing the rear caliper. There are some members of this forum who remove the negative battery terminal as an added precaution.
The caliper tool is designed to retract the caliper piston far enough to allow the caliper to fit over the new brake pads. There is no other adjustment that needs to be performed.
Queen and Country (11-03-2017),
Sean W (10-13-2017)
Received 1,975 Likes
NBCat,
That was my original assumption after reading several different post and procedures, then I start rethinking and now in the process of re-evaluating. Thanks for your input.
I ordered the tool, after seeing one at O'Reilly's. (Amazon 1/2 the price) If everything works correctly and the calipers retract with out any other issues than I think the tools is sufficient. Not like I'm a mechanic using it on a daily basis. Hopefully I'll get to it early next week. And I will post back.
Update on my brake job.
Finally got everything back in order.
The tool I ordered worked fine. I used it with a caliper tool to hold pressure on the piston while I pushed and turned. I will look in to maybe modifying that assembly to make it a bit more functional.
Ran into a significant problem removing my rims. First time I've had to remove them and it appears that somewhere along the way the lug nuts were over tightened. One lug nut had to be removed by using a nut extractor and and cheater pipe on a breaker bar.
Flush the fluid with a hand operated vacuum pump, slow but worked well.
Tested the parking brake and it holds fine. Here in south Louisiana we do not use the parking brakes very often.
I installed Posi Quiet Ceramic Brake Pads with new Centric Premium High Carbon Brake Rotors.
The braking characteristics did change somewhat but after I bedded them in the pads pretty much back to original.
Overall dust at this point is less.
I had to replace the sensors since one had worn (front) and the rear one was broken. Was able to find OEM types for about 1/2 dealer cost. RMeuropean, no affiliation, just better pricing.
The following 2 users liked this post by djhaydel:
ralphwg (11-04-2017)
You will need to screw the caliper piston in (clockwise) while also putting a slight pressure on the piston.
DONOT FORCE THE PISTON IN WITH THE CLAMP. You will ruin the caliper assembly.
The tool I used in the picture worked. In fact I used and inexpensive caliper compression tool with this tool in line .
Then put slight pressure and rotated (with channel locks) the pinned tool . Continued the sequence till it was all the way back in. Goes slowly but it worked very well.
A c-clamp would also work but, you would have to remove it to wind in the piston .
There are other methods of rotating the piston like others mentioned.
There are loaner tools from auto parts but my local AutoZone did not have the correct pin adapter to use.
Harbor Freight also is supposed to have a tool set that works.
For $35 or so I bought the compression tool (locally) and tool (Amazon) with the adjustable pins.
