18 inch Venus rims for 2010 XK
Hello, i wanted to ask if the oem Venus rims/wheels that are 18 inch can be used on a 2010 XK, I currently have 20 in rims and I'm' looking for an all season option for winter months and there are so many more tire options for the 18 inch wheels.
If so does are are there any ECU adjustments needed?
Regards,
Regards,
If you go to tirerack.com you'll see that it shows the revolutions per mile for each tire and tire size. As long as the numbers for the tire you want are relatively close to the tires you already have, you don't need to make any adjustments to the speedometer reading.
I'm pretty sure the bolt pattern for the wheels is the same, but I'm not 100% certain. Someone else will have to answer that.
Has anyone with a 2010 or newer XK had Venus wheels installed?
I ordered a set of wheels recently which were guaranteed to fit my 2010, and Right After I placed the order I noticed that the Offset was listed at 66, which would look RIDICULOUS on an XK. Luckily I called the place and got the order pulled and refunded.
Also, that company STILL lists them as a direct fit for XK XKR.
Panthro (08-09-2024)
Regardless of JAGUAR DEALER or not, ensure that the Front offset is 49, rear is 46 for a 2010.
Regards,
Cee Jay (05-28-2019)
I just searched for just over two hours, and have come to the conclusion that most Wheel Sellers don't give a crap if they list the correct wheels for the XK or not. I only found TWO out of THIRTY different online wheel sellers that ACTUALLY HAVE THE CORRECT OFFSET for our XKs! Seriously. 2 of 30! 28 of them had the 66mm offset listed as Correct for rears on XK, 2010-2015.
Conclusion; if any forum member decides to buy new, refurbished or used wheels from ANYWHERE in the WORLD for their XKs, make DANG SURE that the offset is correct! Even the part numbers are mish-mashed, as "equivalent to Jaguar XK" when they are NOT.
~~~~~~~~~BUYERS BEWARE~~~~~~~~~!!!!!!!!
