1998 ecu and modules with key transponder used on another with different engine
Hi I have build a 1996 - 2005 XK 100 using an ECU, complete wiring and key transponder from a 1998 XJ Sovereign, engine almost wants to start but just wont, how do I go about making the ECU work on a different engine other than the one it came with?
By the way, the XK doesn't have a VIN Number, the car was an assembly model used for training purposes, so I found it completely stripped of everything when i first started building it.
Regards Frank. M (South Africa)
used for
used for
