20" Senta Wheel Bolts
I'm working on a refurbishing of 20" Sentas for my 2007 XKR. The "decorative" bolts have an usual spline design (at least to me). Not the typical internal patterns that I have in my tool box. Does anyone know where to find a tool/driver for these bolts? I'l post the wheels when I'm done.
steve_k_xk (07-08-2020)
[QUOTE=tberg;2258452]Be careful removing them, I believe they are the same as on the Kalimnos, and several of them fought me at every turn. I finally gave up and painted them as well.
You'll thank tbergs plan of attack ^^
Plus if you do decide to remove and polish up (for some ungodly reason) they actually stick out more in the respect the rim doesn't flow and you also run a huge risk of trying to re install without them slipping around and scratching the refurbished wheel .
vintageyz (07-08-2020)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20200709_150129_c29f0791d5e18319d90af82d779f6c745a8d9f74.jpg)
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20200709_145956_2ed24194009bfa210fb2d54152e8a01650ed62a1.jpg)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20200709_145945_d295db72de51be0017701a48bbb6ac6c35092bcc.jpg)
The wheels were finished (except for the bolts) and the tires remounted. I'm still in debate whether to "update" the bolts. My socket, (8mm) arrived and tested on a few bolts with no problem. Before anyone goes crazy on the Sentas, these were purchased off Evilbay with a crack in one wheel and several scuffs on the others. So, I had them repaired and then did the powder coat. The original Sentas are in boxes.
80sRule (07-12-2020)
