2001 XKR Intermittent overheating.
My jag is 23 years old 45,000 miles runs like new all of the time. One exception from time to time the temp gauge buries needle at super hot. Put in about 1/2 cup of coolant and all is well till it happens again. Seems to me thermostat problem but could use some more knowledgeable advice.
How often do you have to put in the 1/2 cup of coolant? Are you filling the black tank right to the bottom of the neck? You need to keep on doing that until it stops going down as it sounds as if your atmospheric expansion tank in the wheel arch is empty. This is not unusual and you will find threads in the X100 forum about how to top it up directly. If repeated fillings do not address the shortfall, it sounds as if you have a coolant leak but it's not enough to lead to overheating which might be caused by a faulty thermostat but is more likely to be caused by a faulty temperature sender. You presumably appreciate that the temperature gauge in the dashboard is not really a gauge at all.
Your post is in the wrong forum so you need to move it for more appropriate advice.
Richard
Richard
Vadim
02-24-2023 07:53 AM
toronadomike
04-05-2015 03:30 PM
Rendro
05-29-2013 09:51 PM
