2007 cooling fans run time after shut down?
Im wondering how often do your cooling fans come on and how long do they stay on after you shut the engine off. Im thinking my Tstat my be faulty. What is normal temp for the engine once fully warmed? I can use the torque app to monitor that for now.
On the 5.0L engine the thermostat starts to open at 190*F and is fully open at 205*F. My 2012 runs at 200*F in normal temps from 32*F to 95*F outside temps. Very rarely do I hear my coolant fan running and so far it has never run after I have shut down the engine after a long run in 85* temps.
Received 2,012 Likes
My 2007 has 82K miles and I've owned it for one year. The radiator fans frequently run in warmer weather after shut down (like now, with ambient high air temps in the 90's.) I've replaced the thermostat housing which contains the engine temp sensor, all hoses, and the coolant reservoir. The fan behavior is largely unchanged after all of that, and they will run for a few minutes after shut down.
Any update on your running temp Brewtech?
Keen to see if this is normal or if I need to address cooling system components like you did before Summer. Something I planned on doing anyways, now just sooner. Not having some sort of temp indicator is probably my only gripe about my XK so far as it is probably one of the, if not the most important data sets a driver needs on a live basis. Everything else has been outstanding, thanks for convincing me to get an X150 BT.
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
-Indy
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1440x1545/1a77f700_2a7b_40ed_bf9b_6f61289674f0_673d50e8411372dc38ba41f0ba824e0c6d0dbf87.jpeg)
David993S (04-11-2024)
To change the functioning of the cooling fan there are two changeable parts. The thermostat may be a hot one. Replacements can run from 85C to 92C. Maybe if you are using a hot one, then the fan comes on more frequently. The other, maybe off calibration. The temp sensor in the thermostat housing may be sending the message to the computer, that you are hotter than you really are.
I have a little OBD2 wired gauge for temp that shows me running at 85 to 87C. So no fan is needed.
steve_k_xk (04-15-2024)
Received 1,123 Likes
Cee Jay (04-15-2024)
I have spent WAY too much time researching this problem on my '07 XK convertible. I have used my Autoenginuity with Jaguar software to read a large number of sensors over many drives, varying ambient conditions, and off and on over 6+ years. In my case, the fan, if on, will start to wind down for a second or two after shutting off the engine. Most of the time (but not always), it will then come back on and run consistently at 50% duty for 4 minutes and 0 seconds, +/-1 second. This led me to believe that a sensor triggers the ecm to trigger the fan control module to run the fan for the prescribed conditions. Note that changing the engine thermostat, for other reasons, had no effect. This didn't surprise me since the engine temperature has been in the acceptable range when I recorded it on many occasions. In the end, I decided to just live with the issue since it doesn't do any harm. I had the opposite occur in my '11 XJ where the fan did not come on and that has a MAJOR impact ($$$) if not discovered in time (I didn't).
The '07 XK has one other temperature-related quirk - the external temperature reading on the touchscreen reads 5 degrees high. I doubt this is related to the fan issue. I just need to calibrate myself when I get in the car since my '13 XK coupe has neither problem.
Dan
Dan
Often people speak of changing the thermostat to correct the fan run on. Take the approach that the thermostat is too hot and a cooler one, would be better. Mine runs at 85C to 87C. Never more. The range offered in the market can be from mine, up to 92C. In the future, try a cooler one. Just don't let the garage decide for you.
All engines heat up a bit more when turned off, then the cooling cycle starts.
