2007 Jag XK P1368 & P1367 Won't Start
I have a 2007 Xk with 43K mileage. I changed the battery about one month ago. Everything has been fine. Saturday I drove to a wedding and afterwards it would not start. The dash displays Engine System Fault. I got it home and pulled the codes and I had three. P1368, P1367, and U0151. I have had my air bag light on for some time which is what I believe code U0151 is telling me. Be the new codes are P1367&68. Does this mean my ECU is bad. Any help would be appreciated or direct me to a previous post. I have search and not found a lot of info. Thanks
Check the battery voltage....should be >12.2v (engine off after sitting for 10 mins). The electrical system will not charge a new battery, it has to be charged with a charger first. Once fully charged, and if not driven regularly, it is advisable to keep it topped off with a maintainer such as a CTEK 4.3. There are many threads on the subject that explain why.
NBCat (08-10-2018)
OK this is a different problem then what everyone is thinking. You say the engine turns over meaning the starter and battery are working but the engine won't fire up. Do you have a check engine light. Can you check to see what codes you have at the OBDII port.
Received 2,626 Likes
I have taken both cables and the voltage is 12.91. I have touched the cables together for 30 seconds and nothing has changed. It still shows the Engine System Fault, it will turn over and sometimes start for about 10 seconds then die.
Any help or ideas are appreciated. I am thinking the ECm.
Yeah, that may be the next step. Since BOTH banks are involved, it would appear that the commonality would be the ECM.
- Faulty Ignition Amplifier
- Ignition Amplifier harness is open or shorted
- Ignition Amplifier circuit poor electrical connection
- Faulty Ignition Coil Relay
- Faulty Engine Control Module (ECM)
Last edited by Cee Jay; 08-23-2018 at 03:15 PM. Reason: Man, the Formatting in this "new" version of the Forums added a few weeks ago SUCKS!!!!
wicklewamb (08-09-2020)
I find it frustrating when someone comes to the forum for help with a problem, potential solutions are offered, and then nothing... I figure the OP's car hasn't sat for 2 years, unable to start. If I am right, then the problem has been fixed. It would be great to know how it was resolved, in case others have similar problems. Also it's a courtesy to those who have invested their time and energy in proposing various solutions. Just sayin'...
Could be. Even so, just as a matter of courtesy, it would have been nice to have seen a sixth post saying "here's how we fixed it. . . " If someone has time to post five times asking a question, it doesn't seem unreasonable to expect a couple of minutes spent posting the solution. Shame indeed.
