2007 Jag XK P1368 & P1367 Won't Start
Old 08-10-2018, 11:08 AM
FHP's Avatar
FHP
FHP is offline
Default 2007 Jag XK P1368 & P1367 Won't Start
I have a 2007 Xk with 43K mileage. I changed the battery about one month ago. Everything has been fine. Saturday I drove to a wedding and afterwards it would not start. The dash displays Engine System Fault. I got it home and pulled the codes and I had three. P1368, P1367, and U0151. I have had my air bag light on for some time which is what I believe code U0151 is telling me. Be the new codes are P1367&68. Does this mean my ECU is bad. Any help would be appreciated or direct me to a previous post. I have search and not found a lot of info. Thanks
Old 08-10-2018, 12:27 PM
pwpacp's Avatar
Check the battery voltage....should be >12.2v (engine off after sitting for 10 mins). The electrical system will not charge a new battery, it has to be charged with a charger first. Once fully charged, and if not driven regularly, it is advisable to keep it topped off with a maintainer such as a CTEK 4.3. There are many threads on the subject that explain why.
NBCat (08-10-2018)
Old 08-10-2018, 01:40 PM
FHP's Avatar
FHP
FHP is offline
I have a charger on the battery all the time in the garage. Voltage stays at or above 12.4. Engine will turn over fine just won’t start.
Old 08-10-2018, 02:43 PM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
Last suspect of all is the "ECU".
A good battery would be 12.6 so yours is near dead. Still may not be it but it's a big suspect.
Otherwise go back to basics for a petrol engine...
Old 08-10-2018, 03:02 PM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
A "Hard Reset" sometimes sorts out gremlins. It's free and easy.
The 'easiest' way is to disconnect the negative battery cable from the battery and hold it to the positive cable for a few seconds. Then reinstall the cable.
Old 08-10-2018, 04:21 PM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
OK this is a different problem then what everyone is thinking. You say the engine turns over meaning the starter and battery are working but the engine won't fire up. Do you have a check engine light. Can you check to see what codes you have at the OBDII port.
Old 08-10-2018, 04:34 PM
FHP's Avatar
FHP
FHP is offline
The codes are P1367 and P1368.
Old 08-10-2018, 04:35 PM
FHP's Avatar
FHP
FHP is offline
Also the dash display states “Engine System Fault”.
Old 08-10-2018, 04:45 PM
Received 2,626 Likes on 1,810 Posts
Before swapping out parts, remove the battery from the vehicle and charge it overnight. After charging, it should have a minimum of 12.6 volts across the terminals for the vehicle to function correctly.
Old 08-10-2018, 05:42 PM
Ranchero50's Avatar
X150 S/M says ignition amp A+B...
I'm going with removing the battery cables and charge the danged thing overnight. Exactly what NBcCat suggests (for good reason)
Old 08-10-2018, 06:22 PM
jagtoes's Avatar
While he's got the cables off , just touch them together for 5 or 10 seconds as a reset.
Old 08-23-2018, 02:55 PM
FHP's Avatar
FHP
FHP is offline
I have taken both cables and the voltage is 12.91. I have touched the cables together for 30 seconds and nothing has changed. It still shows the “Engine System Fault”, it will turn over and sometimes start for about 10 seconds then die.
Any help or ideas are appreciated. I am thinking the ECm.
Old 08-23-2018, 03:14 PM
Cee Jay's Avatar
Yeah, that may be the next step. Since BOTH banks are involved, it would appear that the commonality would be the ECM.
- Faulty Ignition Amplifier
- Ignition Amplifier harness is open or shorted
- Ignition Amplifier circuit poor electrical connection
- Faulty Ignition Coil Relay
- Faulty Engine Control Module (ECM)
Last edited by Cee Jay; 08-23-2018 at 03:15 PM. Reason: Man, the Formatting in this "new" version of the Forums added a few weeks ago SUCKS!!!!
Old 07-08-2019, 11:46 AM
cly's Avatar
cly
cly is offline
Hi,
How was this problem finished?
Sandor
wicklewamb (08-09-2020)
Old 08-14-2020, 03:45 PM
wicklewamb's Avatar
Did you get to the root cause and fix this? Would be interested to know what that cause was!
Old 08-14-2020, 04:41 PM
Cee Jay's Avatar
I haven't done anything on it yet as I have a crap-ton of other stuff going on.
Old 08-26-2020, 08:01 PM
Clinton Patrick O'Rourke's Avatar
Default Same exact issue
Following to see if a fix was ever figured out
Old 08-27-2020, 04:50 AM
barnsie's Avatar
I find it frustrating when someone comes to the forum for help with a problem, potential solutions are offered, and then nothing... I figure the OP's car hasn't sat for 2 years, unable to start. If I am right, then the problem has been fixed. It would be great to know how it was resolved, in case others have similar problems. Also it's a courtesy to those who have invested their time and energy in proposing various solutions. Just sayin'...
The following 4 users liked this post by barnsie:
Cee Jay (08-27-2020), MarkyUK (09-13-2020), peterv8 (08-27-2020), ralphwg (08-27-2020)
Old 08-27-2020, 05:35 AM
peterv8's Avatar
wouldn't suprise me it's a workshop asking for help cause they can't figure it out. 5 posts in this thread is all, shame!:-(
Old 08-27-2020, 07:42 AM
barnsie's Avatar
Originally Posted by peterv8
wouldn't surprise me it's a workshop asking for help cause they can't figure it out. 5 posts in this thread is all, shame!:-(
Could be. Even so, just as a matter of courtesy, it would have been nice to have seen a sixth post saying "here's how we fixed it. . . " If someone has time to post five times asking a question, it doesn't seem unreasonable to expect a couple of minutes spent posting the solution. Shame indeed.
The following 3 users liked this post by barnsie:
peterv8 (08-27-2020), ralphwg (08-27-2020), sov211 (08-27-2020)
Quick Reply: 2007 Jag XK P1368 & P1367 Won't Start
